Hello,
I received a couple of days ago my iron colorimeter and I am testing it now pretty heavily. In the morning before I do my dosing, I do an iron test and I get a 0 value. Using Wet's calculator, I dose the amount needed to have 0.2 ppm concentration in my tank water. After around 30 minutes, I test the water again, and amazingly, the colorimeter reads a 0.2+ value. The colorimeter seems pretty accurate. Around 6pm, I do a test again and I will get a 0 value. I am doing this for a couple of days already and gets pretty much the same values everytime.
Now my question is, should I be dosing more iron in the morning so that I could maintain a 0.2 ppm value even in the evening or my dosing is just fine.
Any advice on this is much appreciated.
Thank you all.
Thank you all.
