Help dial in LED lights
Discussion in 'Lighting' started by Righteous, Apr 28, 2017.
  1. Righteous
    Righteous Subscriber
    Apr 10, 2017
    41
    3:00 AM
    I'm having some difficulty / concerns with dialing in my LED light above my tank. The light is a AI Hydra 26 that I used to use over my reef tank. It's fully configurable and I think it has a good set of LEDs. The unit has the following LEDS:
    6 Cool White (CREE XP-G2)
    6 Royal Blue (CREE XT-E)
    6 Deep Blue (OSRAM)
    2 Violet 415nm (SEMILED)
    2 UV 405nm (SEMILED)
    2 Deep Red (OSRAM)
    2 Green (CREE XP-E2)
    Currently I've got it set to 28% Cool White & Red, 8% Green, 2% Violet, 6% UV, 0% Blues. The light has a good spread. Does the spectrum seem okay, or should I really be getting a different light? I've tried using the light calculator on this site... it's computing about 100 PAR (i have to select BML 30 degree, even though this has 80 degree optics.. that's based on comparing PAR and settings from other Hydra users with reef tanks). At this setting is seem rather dim... but I am used to lighting a reef so that could be part of it. I had it at higher settings for a while and things were growing, but I noticed some green algae starting on the rocks, so I lowered it to this (I'm doing CO2 and EI dosing)
    [​IMG]
    #1 Righteous, Apr 28, 2017
