My name is Florin and I am a nub
Since february I have a 12g nano which I am using as a prototype to learn about the hobby. That was the plan anyway - now I realise that a bigger tank would have made a better prototype but the deed is done.
I have it planted with inexpensive & hardy plants, i.e. egeria, cabomba, cryptocoryne and an anubias. It's inhabited by some corys, some oto and some inverts. I'm only going to "upgrade" the plants when I know what I'm doing. The tank is lit by two Aquatic Nature Solar Vision clip-on lamps, 13W and 26W respectively. I inject CO2 but I am not fertilizing yet.
I made some early mistakes which resulted in de-cycling the tank and I spent three weeks or so doing daily water tests. I bought several brands of chemical testers and I understood how "reliable" they are. They're good as general indications of things, and even for that they fail sometimes (combined with my lack of skill and patience, of course; I've never done more than one repetition of a specific test
Reading around this forum a bit I understood Tom's point about which is the best testing kit: the aquarium. Do small changes, observe results, change again until happy.
Two buts:
1. I am too nubish at the moment to fully understand what I observe
2. Even if eventually I'll get there, I still want to correlate "well-being" to numbers (Tom does that too btw)
So let me get to the point of this post:
I need some help choosing a better test kit. I set my sights on colorimeters. I looked at four products:
Hach DR/890 http://www.hach.com/hc/view.documen...4847000/View=HTMLCAT001/NewLinkLabel=Overview
Lamotte SMART 2 http://www.lamotte.com/pages/common/newprod/smart2.html
Hanna HI 83200-01 http://www.hannainst.com/usa/prods2.cfm?ProdCode=HI 83200-01&id=009003
Thermo Scientific Orion AQUAfast AQ4000 http://www.thermoscientific.com/ecomm/servlet/productsdetail_11152_L11193_80474_12769455_-1
I tried to compare the list of tests that these devices can perform. The point is, if I'm going to spend a lot of money on this device, I'd rather it performed all the tests I ever needed.
Here's a table where I tried to reunite all the tests from each of the 4 lists. I tried to leave out the same test done via a different method (but as I don't really understand any of this, I may have made mistakes).
I colored green what I understand are the "fundamental" water quality tests and with yellow the fertilization-related or niche tests.
Question 1. Did I color the right tests? Does anyone ever test for trace elements?
I saw Tom recomending the DR/890 so I am taking that device as reference. Looking at my table, it looks like Hach DR/890 lacks:
- Alkalinity /* is this relevant? */
- Hardness (total) /* I wonder if this means General Hardness */
- Phosphate /* but it has "Phosphonates" - is that the same thing? */
- Potassium
The others lack various combinations of tests relative to Hach and to each other.
Question 2: is my assessment of the missing tests correct? Which device has the most complete array of tests?
Question 3: which device is the most user-friendly of them?
Thanks in advance for the advice,
Florin
Two buts:
- Potassium
Florin
