Help!!! Advice Needed.
Discussion in 'CO2 Enrichment' started by Lazy999, Oct 4, 2018.
  1. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    10:48 PM
    Guys,
    I just change my regulator metering valve to a swagelok low flow with vernier handle.
    I try slide in the nut and the front / back ferrules as the pic shows. But the co2 tubing can slide out from the nut after i tighten it. Its kind of loose when the co2 tubing go through the front/back ferrules.
    How should i go about tighten it?
    Please advice me.
  2. X3NiTH
    X3NiTH New Member
    Jul 3, 2018
    13
    3:48 PM
    The diameter of your tubing (4mm) doesn't match the diameter of the outlet you are trying to connect with, the conical ferrule when fitted should be on tight enough that it pinches the tubing and can only be removed by cutting the tubing. You're going to need a reducing connection for the outlet to fit your 4mm tubing or replace the tubing with a larger diameter (you'll need a reducing adaptor no doubt for the other end if it connects to a device that uses a 4mm connector).
    Knowing the part number of what you have lets us look up the dimensional tolerances to give exact answers.
    Swagelocks' Installers Pocket Guide to Tube Fittings
  3. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    10:48 PM
    I just check. My swagelok metering valve ss-ss4-a-vh connector is 1/4inch (6.35mm)
    My tubing is 6mm. That explain why its loose.
    If i get a 6mm ferrules set, does its work?
    Or should i get the swagelok tube insert ss-6m5-4m for my tube?
  4. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    10:48 PM
    Update; went down to swagelok and they advice me to get a reducer ss-6m0-r-4 for it.
    Asked them can i just get a 6mm ferrules set and make do with it. They said not adviseble to do so due to the different measurement matrix.
    Although 1/4 and 6mm is very close. Difference of 0.35mm only.
    Anyone using the low flow angle valve ss-ss4-a-vh? Care to share wat mm ur ferrules is?
  5. rajkm
    rajkm Article Editor
    Sep 16, 2015
    677
    218
    3:48 PM
    Always use furrules for the valve. The compression fittings are based on a metal to metal seal and if you use incorrect furrules, you will have leak. If the tube is just about snug, you can tighten it and it will form a seal as you tighten. Other option would be to get a barb to compression fitting and then attach the tube to the barb.
Tags:
