Hello From Palo Alto Ca
Discussion in 'Introductions' started by Jack McCarron, Oct 16, 2018.
  1. Jack McCarron
    Jack McCarron New Member
    Oct 16, 2018
    3:17 PM
    Hey guys,
    I saw some crazy tanks in person and online and became filled with determination. I love moss more than anything in the world:
    I went with a very small tank and am a bit worried! I'm here to learn what I need to make it succeed.
    Tank:
    ADA 45f (45x24x16cm)
    ADA aquasky G 451 (too much light???)
    Shiruba XB-303 filter (very small)
    Hydor external in-line heater
    GLA GRO-1 CO2 regulator
    Lily pipe "spin" outflow
    Hardscape/Substrate:
    A random hunk of wood that fit nicely
    Little bit of ADA power sand
    ADA amazonia base layer
    ADA amazonia powder type top layer
    ADA colorado sand
    In the filter:
    A sponge that came with the filter
    Some bio media that came with the filter
    A packet of activated carbon
    Flora:
    Riccardia Chamedryfolia (not doing so hot)
    Monte Carlo
    HC Cuba (growing up instead of sideways :/ )
    Phoenix Moss
    Java Moss
    Weeping Moss
    Java Fern (needle leaf)
    Fauna:
    Nothing yet, but just wanna get some shrimps
    I am excited to learn... everything.
  2. unay
    unay New Member
    Sep 11, 2018
    12:17 AM
    Hello Jack and welcome! :)
    I’m almost new here also.
    Your project is lovely!
    Just one question:
    Why are you using carbon in the filter?
    Cheers
  3. Jack McCarron
    Oct 16, 2018
    3:17 PM
    Thanks! I put carbon in the filter because I read that it could help with the tannins from the wood. What other effects does it have?
  4. unay
    unay New Member
    Sep 11, 2018
    12:17 AM
    Hi!
    As far as I know (I'm not an experienced aquarist yet ;) ) The carbon will get the tannins, yes, but will take a lot of nutrients from the water too. After some time, it will give back everything to the water again. That's what I have read.
    If you don't use the carbon, the tannins will go out of your tank after some weeks, with the water changes.
    But hey! As I said, I'm not the best one to give advise here! :D
  5. Jack McCarron
    Oct 16, 2018
    3:17 PM
    Good to know! Do you know what nutrients exactly? I did a quick google search for EI dosing + activated carbon and it seems like the consensus is that the carbon will not bind to the ferts. Could it affect plant growth otherwise?
  6. unay
    unay New Member
    Sep 11, 2018
    12:17 AM
    Well, i’ve been reading some debates about it. This is for me the best explanation:
    https://barrreport.com/threads/myth-or-truth-activated-carbon-in-filter-play-any-role-on-plant-growth.12059/
    Apparently it wont remove nutrients
Tags:
