Hello Everyone...
Discussion in 'Journals' started by lofo87, Oct 10, 2018.
  1. lofo87
    lofo87 New Member
    Oct 9, 2018
    6:32 PM
    Hi I’m loris and I’m very enthusiastic about the planted tank world . At the moment I owned 1 planted tank and I try every time to improve my work. At the moment I swapped from diy yeast co2 to citric acid baking soda system and I for me was more easy before with the yeast one I don’t now but I feel the citric acid one last less day for me and is difficult for me reach the co2 target in the water column now .
    sam_08 likes this.
  2. sam_08
    sam_08 New Member
    Oct 7, 2018
    12:02 AM
    Nice tank! Currently I am using vinegar ( acetic acid) and baking soda system but thinking of using citric acid baking soda system. I use passive disolution rather than injecting it into water column but with citric acid system I will use inection system. I didn't consider yeast system, it doesn't provide sufficient pressure. I have two tanks and planning of another larger one. Happy scaping.
    Sent from my Redmi 4A using Tapatalk
  3. lofo87
    lofo87 New Member
    Oct 9, 2018
    6:32 PM
    I
    m using aswl
  4. lofo87
    lofo87 New Member
    Oct 9, 2018
    6:32 PM
    I’m using as well the vinegar and baking soda solution but I will try next week the citric acid and will see if there are any improvement of production of co2 .
Tags:
