Grumpy's GH booster
hani
302
how can i make a solution to add with wc to raise the gh 2 degrees for 75 g tank?
thanks
35 Grams
Hi Hani,
35 grams of Grumpy's GH Booster should add a about 2 dGH to 70 or so gallons of water. :)
I hope this helps. :cool:
hani
302
how much should i add with evry WC? 35 gram is a lot. my water i hardness about 5-6
thanks
I Do Not Produce Grumpy's GH Booster, It Is What It Is.
Hi Hani,
[FONT=&quot]Without regard to the starting general hardness, i[/FONT]f you wish to raise the general hardness of 70 gallons water by 2 dGH using Grumpy’s GH Booster you will need approximately 35 grams, you probably could get away with a couple of grams less. Heavily planted and particularly if you keep gastropods, you may need a little more. Fewer plants and fewer gastropods less may be required. :)
I use a GH Booster at each water change. :gw
Generally, I think it is a good idea to raise general hardness a degree or two, with your water one or two degrees puts you in what many consider the “sweet spot” for planted tanks.
Your question was (sic) “how can i make a solution to add with wc to raise the gh 2 degrees for 75 g tank?” The approximate answer is 35 grams. :)
hani
302
I am having problems now, its 75g tank 2 month old with amazonia 1, my tap water is kh 8 and Gh 6, my tank waer Kh 2, Gh3.
Am having problem with anapis, leaves having a dark green vains and yellow in between.and they are dying from the steam ,am using EI. TMG for trace
so i thoiught it will be magnesium/ iron.
I just added 60 gram of grumpy's booster , re tested in i hour still gh/dh the same.
havent been adding any booster with my weekly change before.
it must be the ada soil, making my water soft?
please help
799
I add about 2 teaspoons 1x a week for GH to a tank this size, more than enough.
hani
302
hi tom,
sorry i do get confused when it comes to teaspoon, how many grams will 2 teaspoon of gh booster will be (roughly)?
thanks
About 5 Grams Per Teaspoon
Hi Hani,
[Additional Disclaimer]
  • I have not and do not use Grumpy’s GH Booster.
Two teaspoons of Grumpy’s GH Booster is around ten grams. :)
Many who use Grumpy’s use it for the other things they get, it seems roughly equivalent to SeaChem Equilibrium. :)
