Hi gang
Been doing planted tanks for 10 years with CO2, EI, good lighting with mediocre success...sometimes things are great, other times not so good. This winter I'll be starting a 180 gal (or there abouts) tank, high tech (adequate lighting, CO2, EI) planted etc. I want to do this tank consistently right, taking everything into consideration to have a high probabaility of success.
Local water report lists pH as 7.8 with hardness of 122 ppm. The water company says in their intro that hardness is measure of Calcium and Magnesium, so is the 122 ppm they refer to the Total Hardness?
Due to desire to add discus to tank and also I want to finally have some great plants, I'm thinking the above hardness is on high side (not sure though) and am considering an RO unit and mix result with tap water to get to desired KH etc. Any thoughts on this?
Also, what is a good accurate test kit?
