Glut only tank re-scape with EI ?
Discussion in 'Non-CO2 Methods' started by Jaydip Saha, Jun 22, 2015.
  1. Jaydip Saha
    Jaydip Saha Junior Poster
    Jun 22, 2015
    6:23 PM
    I started with this 20 gallon tank around six month back and used only excel as carbon source. I have also dosed with macro and flourish comprehensive and got some good result. Later I was using glut (2%) instead of excel. Now I need to rescape it again as due to high temperature and humidity my entire foreground is gone and background steam plants also get affected.
    This time I have planned with 25% glut along with lab grade KNO3, KH2PO4 and K2SO4.However I am not sure about the strength of the glut I will use .Shall I make the strength to excel equivalent(1.5 %) or try with more higher strength like (5 or 6 %). Also for EI shall I try with 1/3 or more for this glut only tank?
    Tank Few months back-
    After summer-
    #1 Jaydip Saha, Jun 22, 2015
