Hi all, My general thread is now so large that I will close it and start anew
Most of the posting is mine anyway lol
Here on page 1 of this new thread I will summarize my current hardware, etc so we are all on the same page, so to speak...it will be easier for folks to review this first page for hardware and setup questions and that do not care about the rest of what I say lol
Tank - 220 gal custom rimless 3/4 starphire all around. 72" long x 36" front to back x 20" tall. Stand is powder coated steel with custom light bar. Clear silicone used and all was built by Coast to Coast in NJ.
Lights - 2 of the 36" 8x39w T5 ATI Sunpower dimmable fixtures. They each have two banks of lights: 2x39 and 6x39. I use a mix of ATI blue and purple and gman middays and aquafloras. Here are those timings. Note the max intensity is < 50%. They are suspended 14" above the water surface.
Bank 1
10:00 am ON
11:00 am 2%
13:00 pm 10%
13:30 pm 40%
14:00 pm 45%
20:00 pm 45%
20:30 pm 20%
21:00 pm 10%
21:30 pm 9%
23:00 pm OFF
Bank 2
13:00 pm ON
13:30 pm 25%
14:00 pm 45%
20:00 pm 45%
20:30 pm 20%
21:00 pm 14%
21:30 pm 5%
22:00 pm 5%
23:00 pm OFF
PAR Summary
Looking at corners/ends at substrate, the LOWEST was 62 and that was shaded by manzy and plants. Usually 70-80 as an avg... The downoi gets 62-72, stauro 70-85, coffeee 75-95, petite 50-81, HG belem 81, HG 40-60, c, parva 75, java trident, narrow, needle 75-125.
Originally I had a 72" 12x39w AquaticLife fixture but switched to the ATI on 6/16, approx 10 months into the setup.
Substrate - ADA Amazonia New Type (post type II). Iirc I used approx 7-8 9 liter bags.
Filtration - Aqueon Proflex Model 4 sump powered by a mag 1800 split into twin 3/4 returns using a 2" wye. 2 of the 3 sock filters have been replaced with block sponges. The 3rd sock filter was replaced by a rolled up carbon pad.
Originally I had twin large eheim canisters (2080), one in each corner, but switched to the sump on 5/26, approx 9 months into the setup. Plant growth and overall health improved dramatically from that point.
C02 - Rio 1000 internal pump in sump with true needle wheel impeller. Intake is drilled and c02 tubing inserted into the hole to keep it tight. Output via 5/8 flex tubing to 9" cerges 'reactor' and then 5/8 flex back to sump. Outflow is picked up by main sump pump. The cerges was installed on 12/1/2012.
Originally I used a single atomizer on one of the eheims, then 1 or 2 (at times) rio 1k nw IN TANK as there was no sump.
C02 comes ON at 12:30 and is OFF at 8:30. I usually use a 10lb tank that only lasts 4-6 weeks.
Regulator configs as I have two of the exact same build but only using 1 currently:
Burkert 6011 (brass) w/ viton seals
Swagelok post body npt components
Ideal valve w/ vernier handle (V52-1-12)
Nuaire/Victor VTS253A-1993 (new)
Fauna - 300 + cardinal tetras, 30 rummy nose, 20 diptail pencils, 10 apisto caucatoides mega red...
Flora - anubias.petite, a.coffeefolia, java trident, java narrow, java needle, hygro araguaia, elatine triandra, hair grass parvula, hair grass belem, downoi, dwarf bolbitus, hydrocotyle japan, fissidens, var mosses.
Hardscape - manzanita from CA selected and placed by Tom Barr.
Tank has been up and running since 8/27/2011.
Current pics and video coming today.
I plan on making some small plant section changes and will document these here going forward..
Here is the link to the original thread for those who have a month to kill:
http://www.barrreport.com/showthread.php/8435-New-Tank-Build-Thread/page159
Later.
Bank 1
10:00 am ON
11:00 am 2%
13:00 pm 10%
13:30 pm 40%
14:00 pm 45%
20:00 pm 45%
20:30 pm 20%
21:00 pm 10%
21:30 pm 9%
23:00 pm OFF
Bank 2
13:00 pm ON
13:30 pm 25%
14:00 pm 45%
20:00 pm 45%
20:30 pm 20%
21:00 pm 14%
21:30 pm 5%
22:00 pm 5%
23:00 pm OFF
PAR Summary
Later.
