Geektom’s 135g Adventure
Discussion in 'Journals' started by geektom, Aug 17, 2018.
  1. rjw
    rjw New Member
    Oct 21, 2018
    1:46 PM
    Nice set-up!
  2. geektom
    geektom Junior Poster
    Dec 16, 2012
    351
    326
    1:46 PM
    Since I was stuck at home today, I decided to at least get some progress done on the tank.
    Got the FX4’s placed and the hoses measured. These filters are designed for taller tanks than mine, so I had to cut down the inlet tubes to make them shorter. I had actually planned on sloping the substrate even higher in the back, so I will have to be careful.
    [​IMG]
    The FX4’s *just* fit under the low stand with enough room for the hoses to come out at the right angle.
    [​IMG]
    [​IMG]
    [​IMG]
    The side panels will extend all the way to the wall, with a cut-out at the bottom for the baseboards.
    After an long delay trying to figure out how to adapt the 1” hoses to an in-line heater and CO2 diffuser- I am throwing in the towel. I just can’t find a solution that works, and it has delayed me over a month already. I can’t lie- I am getting impatient to set up the tank, and my other tanks are bursting at the seams with plants I have been holding onto.
    The disadvantage of the gray background (which I still like) is that the filter pipes really stand out. Now the heater(s) will just make it harder to have a clean look.
    [​IMG]
    My positioning of the big wood pieces will mask most of the inlet pipes:
    [​IMG]
    I am thinking I will have 2 CO2 diffusers in the corners to get pushed around by the outlets, and position 2 300 watt heaters between the pipes to help circulate the warm water, and also help them hide, while still giving me easy access to them. I don’t want any equipment in the middle- both for looks, and because the big top panel would make it hard to reach anything anyway.
    [​IMG]
    Open to any and all suggestions, though!
    Looks like I will not have enough room under the stand for a CO2, tank though. Might as well upgrade to a 20lb tank then, I guess. Anyone paint their CO2 cylinders?
    I will be using 2 diffusers, but they can be the same bubble-count. Can I just use a splitter in the line?
    #22 geektom, Oct 21, 2018
    burr740, Nikolyator and Phishless like this.
  3. toads74
    toads74 Lifetime Member
    Jun 3, 2013
    219
    121
    7:46 AM
    Some places exchange cylinders instead of fill them for you. Can make a cloth sock to fit over it. Or even do a hollow box to fit over it so it will blend in with the furniture and stand. FWIW. The important thing is to make sure it won’t get knocked over.
    #23 toads74, Oct 22, 2018
    geektom likes this.
  4. SingAlongWithTsing
    SingAlongWithTsing Junior Poster
    Feb 17, 2016
    145
    154
    5:46 AM
    hey tom which LFS did you pick up the tank from? need to add my more socal shops to my list lol. Think I'm about 20 mins from riverside
    geektom likes this.
  5. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Where are you at? I wish we had a decent LFS, but we don’t have anything local.
    I got it from Peter at CK Fish World in Azusa, which is pretty much my go-to LFS for everything. He has a great relationship with the folks at Vizio.
    It is not low-iron, and it is not rimless (obviously), and not drilled, so I got a really good deal. I was willing to make some sacrifices to get a big tank weighing my budget- and while old-fashioned, it is built extremely well.
    If you are not a member of SCAPE already (www.scapeclub.org) you should join! Many LFS out here (including CK) give a 10% discount to SCAPE members.
  6. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,298
    7:46 AM
    Boy that's a sweet footprint and height! Great job on the stand and everything too.
    Do you even need heaters? I didnt catch your livestock plans but if the room stays low 70s and up you dont even need a heater for plants and common livestock.
    geektom likes this.
  7. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    5:46 AM
    I'm in San Bernardino.
    Only 2 stores around here I can think of are:
    Petworld SB and Elliot's Pet Emporium. Petworld's been getting some Ultum Nature stuff so it might be worth checking out again in a few months I guess. I can't say much for Elliot's since I rarely go there.
    Didn't know SCAPE got discounts til now xd
    geektom likes this.
  8. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    We are pretty warm here year round, it is true. And during the rare cold weeks (30-40 degree Fahrenheit at the lowest) the house probably doesn’t get below 65.
    The main stars of the tank will be a group of Bolivian Rams, the rest will be some fairly standard tetras, some laser corys if I can find them, maybe a fancy pleco, and clean-up crew, of course. No Discus or cardinals or anything particularly warm-water.
  9. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Elliot’s is good for pet food, but I wouldn’t buy fish or plants from there.
  10. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    First round of hard scape is happening today! Finally!
    [​IMG]
    burr740 likes this.
  11. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Starting to come together
    [​IMG]
    [​IMG]
    [​IMG]
    burr740, Greggz and Phishless like this.
  12. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Really happy with this so far- going to let it sit for a day and look at it with fresh eyes tomorrow.
  13. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Playing with the lights:
    [​IMG]
    burr740 and Nikolyator like this.
  14. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Well, there are some things I *really* like about these lights: there are almost invisible, which is really important to my spouse, and the app/controls are very easy to use and eliminate the need for a timer.
    I definitely messed up by not considering the placement of the large wood pieces before just assuming I should evenly space the lights. That would have worked great with a Dutch-style tank, but with all this hardscape, it just won’t work.
    I don’t want to put more major holes in the ceiling by moving the mounts, however. The lights are not that heavy- I think I can get away with using a strong hook set about 6” to either side, run the wire over that to adjust the hanging position, and keep the original mounts in case I ever want to go to a more traditional tank.
    [​IMG]
  15. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Ok! I have finally decided how I will stock this tank:
    1 black arrowana
    4 red-tail catfish
    1 giant gourami
    155 marble hatchetfish
    It’s gonna be awesome!!!!!
    Mike k likes this.
  16. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,116
    969
    8:46 AM
    How many hatchet phish will end up on the floor? :rolleyes:
    msb and Mike k like this.
  17. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Should I increase it to 250?
    Mike k and Phishless like this.
  18. Phishless
    Jul 13, 2017
    1,116
    969
    8:46 AM
    Just add two Pacu to the stocking list all will be fine.
  19. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    >takes notes<
    Phishless likes this.
  20. geektom
    Dec 16, 2012
    351
    326
    1:46 PM
    Final position on the lights. I am happy with the mix of places for high, medium, and low light plants- and some cool shadows, along with caves and openings for the fish to swim through (which I personally prefer over the manzanita branch look)
    FYI- this is the lights at 65% intensity.
    They can actually be “overclocked” to 125% at a loss of energy efficiency.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
