GDA issues
Discussion in 'Are you new to aquatic plants? Start here' started by rthomas, Oct 3, 2013.
  1. rthomas
    rthomas Guru Class Expert
    Oct 25, 2007
    117
    4:46 AM
    I have been struck with GDA on a 3 footer last week.
    If I were to follow recommendation that says NOT to TOUCH the tank for 3 weeks,
    - do I have to leave the photoperiod as is ?
    - do I need to fertilize the tank as is ?
    Please advise. TIA
  2. Tom Barr
    18,692
    721
    4:46 AM
    You do everything the same, just do not wipe the glass for about 3 full weeks.
    Then wipe real good and do a water change, try and suck off most of it.
    Some folks did a huge water change, then used paper towels etc, or rags to wipe it off and not get it back into the water, then refilled the tank, swished the plants around and other surfaces, then did another water changes right away.
    This worked for me a few times.
    The pack of baby bushy nose plecos or pitbull plecos did the best job, say like 4-5 per 20 gal of tank.
    Several tried this, no one failed yet. Even at extremely high light(100 umol at the sediment etc).
    CO2 tweaking might help also.
  3. Tom Barr
    18,692
    721
    4:46 AM
  4. Kamilstrom
    Kamilstrom New Member
    Feb 21, 2012
    21
    4:46 AM
    I try that on my 5 ft tank,I didn't touch glass over 4 weeks,I did try adjust my light and ferts nothing works,the GDA was always back in week and then I bough 13W UV Sterilizer (cheap on Ebay),I let him work for 2 weeks and wipe glass every day too(keep floating spores) also add bunch Otos(to keep my plants clean) and it's already 4 week after I did remove UV and I didn't see any GDA(sofar work for me).:)
  5. rthomas
    Oct 25, 2007
    117
    4:46 AM
    Thank you all for the input. Really appreciate your valuable advise.
  6. rthomas
    Oct 25, 2007
    117
    4:46 AM
    Quick one
    Would it be okay to make 50% WC?
    The Home Minister complaining that the tank is now giving out some kinda smell ? :rolleyes:
  7. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    4:46 AM
    yes, you can do water changes. Also, once it's stopped growing, it will be easy to wipe off.
