FS: Dual Stage Regulator and Fitttings
Discussion in 'Trades, swaps, sales' started by neilshieh, Mar 11, 2013.
  1. neilshieh
    neilshieh Junior Poster
    Dec 28, 2012
    29
    1:38 AM
    Regulators
    First one is a Stainless Steel Dual Stage regulator by Linde (AGA rebranded their regulator). output can go up to 85 psi. Pressure and Leak tested.
    Components
    -Stainless Steel Linde Redline Dual Stage regulator
    -Stainless Steel Parker H3L valve with turn counter. This valve is more precise than the Ideal NV
    -Clippard Mouse Solenoid (W/ Adapter). Low to no heat, very reliable, very compact
    -Superior Products CGA 320 inlet
    The compression fitting can be changed out to a 1/4" tube od push in fitting upon request. All necessary fittings will be supplied.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    320 shipped priority
    Second regulator
    -Victor HPT-500 Regulator (Fully chromed with Stainless Steel diaphragms)
    -Stainless Steel Swagelok SS-21 metering valve (Super precise and not easy to find one in good condition)
    -Clippard Minimatic Mouse Solenoid (Very reliable, low heat, compact, and very suited for our application)
    -High quality chromed fittings by Parker and Alpha
    -Superior Products chromed CGA 320 inlet
    -inlcudes all fittings needed
    Compression fitting can be swapped out if requested.
    [​IMG]
    [​IMG]
    [​IMG]
    290 shipped priority
    Fittings
    Fittings will be added later.
    but for those who are interested a quick run down of what i have.
    10-32 fittings
    Nickel plated 10-32 manfiold with 3 ports (with one free plug)
    Nickel plated 10-32 elbow
    1/8" npt x 10-32 Nickel plated Bushing
    1/4" tube od x 10-32 SS push in fitting
    10-32 nickel plated brass nipple
    Standard pipe
    1/4 npt pipe (I have both brass and chromed)
    1/4" tube od x 1/8 npt push in fittings (I have both brass and chromed)
    1/8" npt Nickel Plated street elbow (fmpt x fmpt)
    1/8" npt Nickel Plated street elbow (mpt x fmpt)
    1/8" T-fitting (fmpt x fmpt x fmpt)
    1/4" npt x 1/4" tube od stub (Stainless Steel by Swagelok)
    1/4" fmpt needle valves for on and off (chromed, come with free 1/4 nipples)
  2. magicmagni
    magicmagni Prolific Poster
    May 15, 2005
    55
    1:38 AM
    They both look really nice,
    BTW what is the max pressure adjustment on both?
  3. neilshieh
    Dec 28, 2012
    29
    1:38 AM
    the linde can output 4-85 psi and the victor can output up to 45 psi. these are enough to run all diffusers on the market.
