FS:CPR overflow,Flex mini,Mesa dual Regulator,Current LED "18-24"
18,696
740
A few odds and ends of equipment laying around.
CPR CS50 overflow: 40$
Flex mini LED: 45$(new)
Mesa Dual stage Stainless steel regulator, new, liquid gauges: 120$
Current Satellite LED (dual rows)with controller for 10-20 Gallon tanks: 30$.
3" x 36"L heavy duty clear PVC: 20$
ATI also............
4x24W 300$
8x54W ATI, needs work, and likely by pass the dimmercontroller an drewire for simple standard operation: 150$, 190$ shipped.
18,696
740
UDGags said:
Does the CPR CS50 have enough room to add another pipe (herbie) on either the bottom or side? Thanks
Sent from my SM-G900V using Tapatalk
Yes. It does.
Gilles
645
40
Netherlands
The Mesa Dual stage, how much PSI does it deliver and can it be made to fit a european (DIN477) co2 cilinder? I never DIY'd one so i'd need some help with the parts.. To much threads with dead links on plantedtank.. Lost in the threads...
18,696
740
Mesa was sold already. You can buy adapters for the fittings.
18,696
740
I think I have another one, a full SS unit, SS burkret, Ideal valve, SS swagelok check valve.........no one wanted to spend the $ though.
Prime stuff. I do have a Swagelok reg dual stage, but it had a defect in the inlet, likely could be sealed up, but..........I also have some mini regulators, air products, those are 150$ each, nice for small set ups.
