fs: a couple sweet regulators
Discussion in 'Trades, swaps, sales' started by oldpunk, Nov 3, 2012.
  1. oldpunk
    oldpunk Guru Class Expert
    Dec 1, 2009
    427
    2:32 PM
    Oldpunk needs to clear a couple of these out to make room for more. Both regs have been tested and work flawlessly. They are extremely easy to adjust and are easy to use.
    First up, The brass one.
    - Harris 3201 brass bar stock regulator (goes up to 50psi)
    - Ideal V52-1-12 metering valve
    - Burkert 6011 solenoid
    - Brass bubble counter - with redundant check valve (let me know if you're not hip to the bubble counter and I'll stick a barb on there for you and knock off $15.
    [​IMG]
    [​IMG]
    $250 + shipping (will vary depending on location)
    Now here's one you don't see every day. (This unit is solid stainless - all parts)
    - A 'like new' Airgas Y14-C445B regulator (Made by Parker) (Does 60psi max)
    - Parker HR series metering valve (WAY more than you need - super precise)
    - Burkert 6011A solenoid - 24VDC - runs cooler than it's 120VAC relative - Comes with the DC adapter.
    - All Swagelok fittings (Cajon/Swagelok)
    - Leak proof tube fitting for your co2 hose (1/8 ID, 1/4 OD tubing, like gla's)
    - Comes with a glass bubble counter
    - Comes with extra ferrels and inserts for the tube fitting.
    - Very compact for a 2-stage
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    $375 FRIM (You will never see one of these go for any less) + shipping (will vary on your location)
    Thanks for looking. Paypal only please.
    -Josh
  2. oldpunk
    Dec 1, 2009
    427
    2:32 PM
    Both regs are sold.
    #2 oldpunk, Nov 4, 2012
