I will sell for $140 Shipped in the USA (Comes with 2 x 92 watt 6700k compact fluorescent bulbs for planted aquariums)
If you have saltwater, you can replace the bulbs to 10000k if needed)
This light strip will fit aquariums up to 36" wide
(adjustable mounting legs included)
Dual fans for cooling (one of the fans makes a little noise, sometimes you just need to tap on it and it stops making noise.
Light fixture is in great condition
Below is pictures of the actual light you will be buying, also shown is the light strip mounted on the top of my 29 gallon planted tank.
•Two on/off switches with two 8-foot power cords for separate timers
•Built-in ballasts
•Two cooling fans
•Sleek aluminum housing
•Highly-polished reflector
•Acrylic lens cover
•Comes with a 96 watt square pin compact fluorescent lamps
•Fixture measures 36"L x 7"W x 2 1/2"H
•Voltage frequency: 120V 60Hz
•Power: 120W
Here's is a video of the light in action - [URL="http://www.youtube.com/watch?v=_G4p8vM4mBg"][URL="http://www.youtube.com/watch?v=_G4p8vM4mBg"]http://www.youtube.com/watch?v=_G4p8vM4mBg[/URL][/URL]
•Built-in ballasts
•Two cooling fans
•Acrylic lens cover
•Power: 120W
