Fixture height from the substrate
Discussion in 'Lighting' started by soham, Mar 29, 2013.
  1. soham
    soham Junior Poster
    Dec 13, 2012
    19
    11:20 AM
    Hello, my tank dimension is 90X45X45. I have 4 osram T5 HO 39 watt 6500k tubes over it, presently i keep two units on. Substrate height is around 3 inches.
    Now please let me know how many tubes should be kept on and what should be their height from the substrate (i have aluminium reflector) to achieve "high light" condition but avoiding algae at the same time. I have lots of stems, glosso and hydrocotyle.
    I am supplying enough CO2 and Full EI with water change.
  2. dutchy
    dutchy Plant Guru Team
    Jul 6, 2009
    11:20 AM
    "high light" and "enough CO2" are not very exact figures. But, with the tank dimensions you have, you should be ok with just two tubes + reflectors if they are reasonably close to the water surface, around 4 inch. That should give you enough PAR to grow every plant you want.
  3. soham
    soham Junior Poster
    Dec 13, 2012
    19
    11:20 AM
    enough co2 means over 25 ppm. Thnx for the info, one more thing, will it be intense enough to make them red?
  4. dutchy
    Jul 6, 2009
    11:20 AM
    25 ppm might not be enough, better aim for 40 ppm. The light might be enoigh dor some plant coloration in the top part.
