36-ml of 1% KMnO4 solution to your tank
Hi Shawn,
By my calculations, you should add 36-ml of 1% KMnO[SUB]4[/SUB] solution to your tank. (Actually it works out to 36.2-ml.)
Add another 36-ml of 1% KMnO[SUB]4[/SUB] solution to your tank any time the water goes murky, brown, yellow or suddenly clears before the 4-hours are up.
ShadowMac;81077 said:just to be sure I have this right...
I use 2 ml of the 1 L KMnO4 solution that contains 10 g KMnO4 and add that to the tank. Correct? monitor for a color change over the course of the next 4 hours.
EDIT: I added that and it had to be way too little, as I started to suspect...it did not change the color long and dissipated til I could not see it. Should I really be adding 181 ml of the solution since my tank is approximately 181 liters?
Hi Shawn,
