Hello all. I've been lurking for a while and trying to soak in as much as possible, but I've gotten to the point where I need to ask some questions to make sure I am on the right track--and how to fix a few things. Also be advised several plant IDs may be wrong--some were bought by wife and I am not sure exactly what they are.
Specs:
Substrate: basic rock with ~1" layer of laterite underneath
CO2: CO2 misting through Maxijet 1200 (impeller fins cut) @ ~3-4bps
Dosing: Scaled EI for 50 gal (.5 tsp KNO3 + .125 tsp KH2PO4 3x per week, CSM+B+MgSO4 dosed at 12.5 ml 3x per week (from 500mL solution of 1x tbsp of each); 50% changes weekly
Lighting: Coralife Freshwater Aqualight Double Linear Strip Compact Fluorescent Fixture, 2X96 Watt 6700K compact fluorescent lamps @ 10hrs
Filtration: Aquaclear 70
Total circulation: 835gph
--300: Aquaclear 70
--240: Koralia Nano
--295: Maxijet 1200
Flora:
--Cabomba furcata
--HEMIANTHUS CALLITRICHOIDES
--Rotala Indica
--Hemianthus micranthemoides
--Sagittaria
--Cladophora aegagrophila
--Bacopa
--Flame Moss
--Hydrotriche hottoniiflora
--red nesea
--dwarf hairgrass
--Val. contort.
--sword
Fauna
--2x Pleco
--1x rainbow shark
--5x mollies
--1x gourami
--1x glofish
Issue 1: Algae
BBA...I think. I have this over the hydrotiche, cabomba, and edges of the sword. It has taken over the stalk of one of the larger cabombas, totally covers several saggitaria leaves. Tried a weeks worth of 3x recommended does of excel with no effect. Discontinued when vals I had bought finally arrived.
BBA on hydrotriche. I don't have green water so the color is a little distorted. The dots are dark--close to black.
Same as above.
Here it is on the sagg., a bit obscured by the GSA(?) on the glass. Color is better than in other pictures.
And on the edge of sword, best seen in the center of the picture.
break break
Green Algae (other than on the glass)
Quite a bit of it on rocks, but not much noticed on plants as below:
The chicken wire is covering planted dwarf hairgrass, HC, and HM while they root to keep the wife's plecos from uprooting them before they have a chance to start. Intend to keep for no longer than 3x weeks.
Cabomba issue:
I have noticed--beginning today--that the tips of several of the red cabombas have started to turn white--since I took the pictures one of them is starting to rot at the stem:
This morning was the first time since I started injecting CO2 (5x days ago, previous to that was doing DIY-yeast) that I did only one of the lights (96w). After a few hours this is what I saw. Probably unrelated but should mention.
Fish issue:
Might be upping CO2 too much, too rapidly. They aren't gasping at the surface, and we have had some problems with fin rot or something (5-6x deceased of various species), but a couple of the mollies are splitting fins now that hadn't shown any signs previously. The gourami has what looks like a bruise in front of its gills--reddish. Was able to cure one of the mollies before of tail rot/split tail (heh) so maybe there is just a bug going around.
I think that is about it for now. Like I said, a few issues, and just need a bit of course correction. Will update with test values soon.
Appreciate what you guys do here--really helps people to get into and enjoy the hobby.
And stimulate the economy.
-Kirk
Specs:
--300: Aquaclear 70
--240: Koralia Nano
--295: Maxijet 1200
Flora:
--Cabomba furcata
--Rotala Indica
--Sagittaria
--Bacopa
--Flame Moss
--red nesea
--dwarf hairgrass
--Val. contort.
--sword
Fauna
--2x Pleco
--1x rainbow shark
--5x mollies
--1x gourami
--1x glofish
Issue 1: Algae
Same as above.
break break
Cabomba issue:
Fish issue:
-Kirk
