Fighting BGA and its winning :(
Gbark
Jun 15, 2009
266
I have been fighting a BGA out break for several months now.
The tank has been set up for 3 years.
I tried a black out for 4 days, which killed it off, but it came back.
I hoover it up every week but it just comes back.
I do a 50% weekly water change with RO water.
I have not changed my dosing schedule.
I have never had it in the 3 years that i have run the tank.
I keep CO2 stable.
I have changed my light fitting to a single 150w halide from 2x 24w T5's, i presume this is causing it.:mad:
Thoughts please :)
So, bascially you increased the light intensity and PAR but did NOT increase ferts and c02?
I see a possible correlation here :)
Ensure your filters are clean as well as this has caused BGA for me in the past..Low nitrates can also be a trigger or possible cause...
How is your maintenance schedule? Plants grow over 3 years and c02 and ferts must be adjusted.'
Hope this helps.
Gbark
Jun 15, 2009
266
Thanks for the reply,
I have learned that there is always room to increase the CO2, and i do keep it at the high end. I don't really want the CO2 any higher as it already keeps my fish on the lethargic side. I have not increased the amount of ferts, so maybe i should, i will do a sample for NPK before water change.
Organics in the water! i do clean my filter every week. Maybe i should add some carbon?
I know people get good results by dosing Hydrogen Peroxide or Myacin, but i want to kind of find out why it is occuring.
Gbark
Jun 15, 2009
266
N=18ppm
P=1ppm
K=90ppm
work needed here i think. I am quite shocked at the K result, is this a problem?
I will do a few large water changes to reset tank this week.
Not really.
Water changes, clean the tank better.
You might do a 3 day black out of use antibiotices etc.
Then clean more often.
Good current and surface ripple also will help reduce/remove organics(more O2).
Gbark
Jun 15, 2009
266
I will clean and change water twice a week for a month and so, and i may try another blackout, going away for the weekend so that may be an ideal time to put a black out into effect.
I will report back.
