Fertilized substrate or not ?
Kharn
Hi everyone :)
Im in the procces of setting up a 120g tank.
I have bought Florite red and peat..
Im just wondering if this will be enough or should i also buy ex Powersand or something similar to get the substrate Fertilized.
Im using presurised CO2 and EI.
Dont wanna do anything wrong this time hehe
Best regards Jimmy from Sweden
PS i know theese questions might been answerd in other threads but its in the middle of the night here and im too tired to find them ..im of to bed now 3 h untill work sigh.. :)
riverrat
Sep 6, 2005
Re: Fertilized substrate or not ?
I am no veteran of planted tanks yet. I am still a noob. But from what I have read. The concenses would be to gather as much mulm from a established tank as possible. Then dust the bottom of the tank with peat. Don't over do it. You should still see the glass through the peat. Then add mulm and substrate. Thats it!
Probably best to confirm this with more seasoned hobbyist. But I'm pretty sure this is the way to go.
Good Luck
riverrat
787
Kharn said:
Hi everyone :)
If you are going this direction, you need not worry about the substrate except uproot the plants and fluff any excess mulm out of the substrate once twice a year.
EI is going to provide all the ferts you need and allows the plants to grow very well right away.
Main things to consider whenever setting a new tank up:
Use all the mulm you can find and add to the filter and to the gravel
Add a little ground peat
Plant the tank very heavy from the 1st day(this is the most common new tank set up problem, do not "wait for the plants to grow in"!!!).
Crank the CO2 and fertilize at about 1/2 dose for the first week and do water changes 2x a week for the first 2-4 weeks and keep up on things.
