Ferrous Sulfate Questions
Left C
Sep 26, 2005
2,500
73
Burlington, NC
I have about one pound of ferrous sulfate. It is light green in color and it has an almost sandy, powdery consistency. I do not know if it is anhydrous or one of the hydrated forms. It is simply labeled 'Ferrous Sulfate.'
Is it possible that it can be used a substrate amendment or for dosing iron? If so, how much? Will it kill aquarium mosses and fissidens at this concentration? Wikipedia says: "In horticulture it is used for treating iron chlorosis. Although not as rapid-acting as iron chelate, its effects are longer-lasting. It can be mixed with compost and dug into to the soil to create a store which can last for years. It is also used as a lawn conditioner, and moss killer. All iron sulfates dissolve in water to give the same aquo complex [Fe(H[SUB]2[/SUB]O)[SUB]6[/SUB]][SUP]2+[/SUP]." Ferrous sulfate monohydrate is used in such moss killer products as Scotts Moss Control and Ortho Moss-B-Gon.
http://en.wikipedia.org/wiki/Iron(II)_sulfate
http://gardening.wsu.edu/library/lawn003/lawn003.htm
http://bryophytes.science.oregonstate.edu/page22.htm
Definitely Not the Monohydrate
Hi Left C,
If it is green or bluish-green it is the heptahydrate (*7H2O). I guess you can get the tetrahydrate (*4H2O) by heating, don’t know why you would want to, it wouldn’t be the nice green anymore.:D
Iron sulfate can be used in aquariums; it is not as fast acting,it releases iron in a plant friendly form over time, complexed by biological action. :)
As long as you used the iron sulfate as you would any other, you should be okay. I think one of the articles you referenced said if using in the substrate, use 2% by weight, which sounds about right.
If you wanted to use it the aquarium, mix up a 10% solution, then dose as you would any other 10% iron solution. I do not think it will be as effective as chelated forms, but it also won’t be an herbicide either.:eek:
If you have some chelate, EDTA, DTPA, Vitamin C, what have you that can help.:cool:
Left C
Sep 26, 2005
2,500
73
Burlington, NC
Thanks a bunch, Biollante. I've had this ferrous sulfate for a few years, but I shunned using it. It is good to know that it is heptahydrate. I can do the math now to make some solutions. The herbicide part threw me a curve. I was sure that it was the very high concentrations when it acted as a herbacide, I just didn't know how low of a concentration to make. Now I can make one because of your help. I have over a pound of it and I wanted to use it. It should last a long time. I'm going to add some of it to the substrate in a new tank like you mentioned. I'll have to pick up a chelate product.
Thanks a bunch for your advice. I really appreciate it.
