Fe EDTA 11% - Need help
Discussion in 'Aquatic Plant Fertilization' started by Omar EAZi, Jul 19, 2017.
  1. Omar EAZi
    Omar EAZi Member
    Jun 27, 2017
    49
    47
    6:47 PM
    So I ordered the Fe EDTA 11% dry fert from GLA, I checked on rotalabutterfly calculator and it said to mix 44.7 grams with 1000ml of water, and dose 10ml into my 65gallon tank, so I went and did that, my water looks red now, is there something wrong with the calculation or is this normal?! never used any other Fe besides Seachem Fe, and water would only get red with Seachem Fe when I used to overdose sometimes. If anyone knows anything about this please help me out.
  2. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,295
    6:47 PM
    Pretty sure you have DTPA 11%, not EDTA., which is just a different chelate. Either one should not turn your water red at this amount
  3. rajkm
    rajkm Article Editor
    Sep 16, 2015
    677
    218
    12:47 AM
    I agree with burr740. GLA sells DTPA which gives the water a light yellow tinge at higher ppm. I use it too .. never had red color.
    The solution color will be reddish brown.
  4. Omar EAZi
    Omar EAZi Member
    Jun 27, 2017
    49
    47
    6:47 PM
    Yes sorry my bad, it's DTPA, as someone suggested on another forum, it might be the Fe reacting to ammonia, so I have a busy night today doing major water change. I think adding the huge livestock suddenly gave me an ammonia spike.
    yeah the sollowing looks reddish brown(dark). the 44.7grams for 1000ml of water sounds reasonable right?! that's what I'm worried about.
  5. Julia Adkins
    Julia Adkins aquariumfertilizer.com
    Jun 22, 2015
    172
    42
    12:47 AM
    These are the mixing and dosing instructions for iron chelate 13% we give in our website: Mix 1/8 cup (20 g) in 1/4 cup (62.5 ml) water to make 10,000 ppm solution. Add 1/8 teaspoon (1.25 ml) of this stock solution to 12.5 gallons (47.3 L) water for an initial concentration of 0.26 ppm. Periodically add stock solution at this dosage or as required to maintain about 0.10 ppm iron in solution.
    And yes, 44.7 g in 1 liter of water is too much. Iron is a micro nutrient and the plants only need a very small amount.
    Omar EAZi likes this.
