Excesssive Pearling?
Frank Lawler
Apr 15, 2009
60
My plants are all growing well with N,P,K and traces fertilization, as well as pressurized C02, but recently there has been a sudden increase in both brown algae and pearling. The Parrot's Feather in particular is covered in bubbles, and to a lesser degree the Wisteria as well. On the later, much of the pearling seems to come from the beginings of algae growth along leaf edges.
It seems odd that I should be battling algae in a heavily planted tank with good growth.
Might there be a connection between this problem and such extreme pearling? Thanks.
Frank Lawler
Apr 15, 2009
60
Well, it is the same amount I've had for several months: 55 watt @ 8hr/day over 29 gal, although I did put in a new bulb last week.
dutchy
64
The Netherlands
Changing a bulb can make quite a difference in PAR. I've measured differences up to 30%. Maybe because of the increase in light there's a CO2 deficiency, hence the development of algae.
