Excel - 7 day substitute for c02 gas?
Hey all,
I need to refill my tanks but the refill business is closed for a week of vacation.
1. Can I use Excel for a week as a substitute?
I know it won't be as good, I am more concerned that the plants would suffer.
I would only dose per the instructions........
2. Anyone know of a c02 refill near Boca Raton, FL?
Thanks,
Carissa
Jun 8, 2007
678
I'm not sure, but Excel will at least help prevent too much algae. I would reduce lighting, anyway, until you get your co2 back. This will prevent deficiencies from getting too aggressive.
Thanks Carissa.
I already reduced to 7 hrs daily...............
I should have mentioned that..........
ceg4048
240
Gerry,
Reducing the duration does not compensate adequately for loss of CO2. You have to reduce the intensity - by at least half and more likely by a factor of 4.
Cheers,
tedr108
514
Los Angeles, CA
Gerry,
I just go to a fire extinguisher company for refills. You should be able to find one near you easy enough.
Ceg,
Got it. I will raise the lights to their max.
1/2 or a factor of 4 could be tough as I have 3 150w MH bulbs.
Even if I remove one or two, there will be NO light in those sections. I could keep the middle one, but then the ends will be dark........
Ted,
Yes, I am using a fire extinguisher company. Seems to be the only one in my area that does this. Plus, am at work, so web searches are blocked.......
Is why I always use the same place...........
A week can't go by fast enough here.........
Just when I thought I was making progress :(
Thanks again to all.
shane
269
Gerryd,
I usually get my CO2 refilled at AirGas. I believe they are nationwide? I usually drive the CO2 tank there and they fill it up on the spot. Not sure if AirGas is in FL. or not.
captain_bu
Nov 7, 2007
55
SF Bay Area
These look like they would be the two closest AirGas choices for you.
721 NE 45th St, Oakland Park - (954) 772-1920
2455 E Sunrise Blvd, Fort Lauderdale - (954) 563-1127
Hope that is helpful but I am not certain about the Oakland Park location, it comes up with a Google search but not a search on the AirGas site itself.
Shane,
Thanks for the tip. Will try.
Captain_bu, Thanks for the search. That was very kind of you.
I will check it out...............
Thanks again.
Mooner
344
Colorado
At least here in CO, Airgas will not touch them unless the tanks are theirs (leased).
The Fire Extinguisher place will sell you a bottle and fill it. But I was told that you own the bottle and all inspection (yearly) come out of your pocket:(
With the lease, the only thing you ever pay for is the fill. Might inquire before purchase.
Update: got it
Hi all,
Got em filled. Thanks to all who replied and Ted for the winner:
1) BOCAFIRE | Quality products and services in the areas of fire protection, safety and security at a competitive price for commercial, residential, industrial, marine and restaurant needs.
Boca Security & Fire Equipment‎
4201 Oak Cir # 45, Boca Raton, FL‎ - (561) 368-1012
$20 for 5 lb and $29 for 10 lb refill. A little more than the other place, but closer. Had to leave them for p/u next day.
BTW, no adverse affects on the plants. Kept an eye on them and they seemed fine, just no pearling with no c02.
Pearling now and they seem happier, at least I am................
Thanks again!
