Estimative Index Recipe
barrreport.com
Nov 20, 2011
1,580
381
83
UK
barrreport.com
Ive decided to flood my emersed cliff scape in the next few weeks and im going diy with the ferts so I'm interested in seeing what you guys use in your recipes and also wanted to check if my planned one is ok?
Tank 60lx30hx45w or 80litres / 21 gallons
Co2
Tmc 1500 tile
Ro water
Macro Solution
4tsp Potassium Nitrate
1tsp Potassium Phosphate
6tsp Magnesium Sulphate
500ml Water
Micro Solution
1tsp Chelated Trace Elements
500ml Water
Dosing:
Macro 3x a week. Mon, Wed, Fri (10ml per 50ltr of water)
Micro 3x a week. T is for trace so Tue, Thurs, saT (10ml per 50ltr of water)
Sunday is rest day so nothing...
50% weekly water change.
18,695
736
I might add vinegar to the trace mix HOT tap water(say 10 mls of 5% distilled).........shake good for a minute or two, then add the trace mix. DTPA can be added. Or Fe Gluconate or both.
Since there's RO water, you should blend part tap with the RO, or add GH booster after the water change at the very least.
KH via baking soda if you use 100% RO. Maybe enough for say 10-20 ppm alkalinity.
barrreport.com
Nov 20, 2011
1,580
381
83
UK
barrreport.com
Thanks Tom
Just for reference the trace consists of
Fe 8.2% (EDTA Chelated)
Mn 1.82% (EDTA Chelated)
Zn 1.16% (EDTA Chelated)
B 1.05%
Cu 0.23% (EDTA Chelated)
Mo 0.15%
I have both baking soda and salty shrimp re minerise kh+ does it make any difference on the product that is used?
