The new "el Viejo" method is a new aquarium path I'm developing. Basically consists in read all you can about everything and its mother, hear (and read) the advices from experienced aquarium hobbyists and finally... do what you can, because you are too lazy or too dumb to follow a standard way to do those things.
Here is the new "el Viejo" aquarium project. Ingredients:
- 120x50x50 cm tank (around 47x20x20 inches) for 300 liters (around 79 gallons)
- 3 x 54w of T5 lighting (1x4000ºK and 2x10.000ºK - I had troubles to find other temps... but plants will grow fine with these, I wish)
- 200w heater
- medium size internal filter (temporary)
- 20 liter (5 gallons) of garden compost substrate (has been soaking for a month or so)
- 24 kg (55 pounds?) of black gravel (3-5mm)
- 5 x Pogostemon helferi (for carpetting)
- 2 x Hygrophila polysperma “Big leaf”
- 1 x Microsorum pteropus “Windelov”
- 1 x Ceratopteris thalictroides
- 1 x Hemianthus callitrichoides ''Cuba''
- 1 x hygrophila corimbosa “siamensis B”
- 1 x microsorum pteropus
- 1 x rotala sp “green”
And a lot of white stones of different sizes (came from a friend, who used in the past for his aquariums but moved to other designs).
Oh! And a wood piece I get from another friend. I have no clue where it came from, not the wood type. It has been in the garden from at least three or four years and it doesn't float. We soaked it for a week or more.
The process:
- small carpet of substrate
- first deployment of the biggest stones, making a wall
- medium sized stones read the wall to raise the ground without wasting substrate (I was too short of it)
- the rest of the substrate until an inch or more were covering all the planting surface
- around 1,5" of the dark gravel
(in the process I used more medium stones, substrate and gravel to raise the wall, because I like how it looked when I put them at the first time)
- adding enough water to cover all the substrate by almost 3 inches of more with it
- planting
- full filling of the tank
Up today, just three plants have decided to not keep their roots in the ground (one of them was replanted yesterday, another other one decided to float just tonight and I had to go to work, and half of my "cuba" was floating, and I've decided to keep it there to fight algae, shadowing the tank and getting nutrients from the column water).
I'm planning to add more fast growing and shadowing plants (floating egeria, maybe) to prevent the algae boom I'm expecting to raise some dangerous limits.
The stats of my water are a bit high for chemicals (but nitrates and nitrites, that had not peaked yet), but my test kits are not good and I am not sure if I must stabilize them before the cycle is finished.
The cycle must be faster than exepected, because the stones came from aquarium tanks and the filter has been in a cycled aquarium from four months or more. I'm planning to start adding critters sooner than expected, and they will be mainly algae fighters (SAE and shrimp... whatsoever will be tougher, because I want not to "kill" or harm really anything).
The filter has proved to be too small for the tank, although the floating dirt has not cleared yet. It maybe will be enough for filter the tank when plants will have grow enough, but anyways the tank has not enough current to be sure any nutrients will reach every place of it. I must add a pump or another filter, I'm not decided yet..
I want to give you thanks for all your advices (although I've not followed all of them), and will be happy to keep my butt around to continue learning from all you.
From now I will keep things at they are. I want not to Excel it while the plants grow, and I will keep all the lighting at their max seven hours per day (I will give me more light time, but raising it slowly) until the dirt cloud disappear, to give enough intensity to the ground plants. After that, I will decide how many of the tubes and how many time I keep them on (one, two of all them).
Wish me (and my plants) luck
- 200w heater
The process:
- planting
