Tom,
I am not sure if this question has ever been asked and answered:
In your EI article, you write:
I played around with the amount and eventually got there. But I wonder if there is a better starting point, if you have less light.
Thanks,
Frank
Well, what is the relationship between the dosing amounts and the light? Let's assume I have 3 W/gal PC, how would you start? Obviously, you can reduce your dosing, but how much is safe? Would you reduce the amount or the frequency?A typical routine for a high light tank with low fish load:
Volume 80 liters (20 gal high standard tank)
5.5 watts/ gal. - two 55watt 5000K/8800K lamps
1/4 teaspoon of KNO3 3-4x a week (every other day)
1/16th-1/32nd teaspoon of KH2PO4 3-4x a week (every other day)
Traces added on off days as the macro nutrients, so 3x a week, 5mls each time.
SeaChem Equilibrium 1/8 teaspoon after water change.
Thanks,
Frank
