I just wanted to make sure the way I pre-mix my ferts that I'm not making anything unusable to the plants or causing any chemical reactions I am not aware of.
I follow the EI method (plus a few additions) for my 26gal tank. I alternate days with the Macros (NPK) and Micros (CSM+B).
I dose early in the morning so I pre-mix the days ferts the night before in water from my tank.
Am I causing any problems by mixing the following ferts and letting it sit overnight?
Macros (NPK) + Excel:
I mix the N, P and K with water and add a couple ml's of excel. From what I understand, there is no problem pre-mixing the NPK but am I causing any issues adding Excel to the mixture. I use a container that holds about 2 cups water and add the ferts to that.
Micros:
I mix the CSM+B, Excel (2ml's), Flourish (2ml's) and Flourish Iron (1ml) in 2 cups aquarium water the night before I dose. Anybody see any issues here? I understand that I am dosing additional Iron and Micros beyond the EI recommendations but my plants are doing so well and I have no algae issues so I am hesitant to stop adding the small amount of the Seachem products I have been adding.
I am running two 2L Bottles DIY CO2. My drop checker stays nice and green with 5dkh water so I'm not sure the Excel is even necessary, but as I mentioned, it is working very well. Just want to make sure my pre-mixes are not doing something chemically that I am not aware of.
Any thoughts??
Micros:
Any thoughts??
