Steve, I'm in Sacramento
I go to Tahoe all the time.
I know most of the hillbilly backroads, as that is where I often explore wherever I live.
I can do some work for you if you want.
PM me.
I travel to the Bay area weekly do do work for clients.
I ain't cheap, but I can get things going and then you can relax and have things set up easier and be able to do it yourself. I did that for a client in LA.
Results:
The tank looks much better than this now, this was about 9 months ago
I'd suggest a sump/overflow, Bag filter, some sponge and about a Iwaki RT 55 or so.
As far as adding more circulation, the Sureflow Adaptors for the Maxi jets or the Seio Rio pumps are excellent, one or two would be plenty.
No, the drop checkers are not particularly good IME, they are slow response and they are not easy to determine the color.
WC- the hot and cold tap is all you need, add directly and plumb right into the tank. You can test via your hand and it's about accurate to 2 F so you can adjust the tap to suit easily. No need to pre mix water and then add to the tank later, this is not Marine saltwater fortunately.
Amano shrimp can last awhile in the tank, but adult Discus will eat any they can catch. 200 is more like the numbers you need.
Also, with clients, I get all live stock at wholesale.
So the cost is much much lower(wholesale + 10%), even though I'm not cheap.
I make up cost savings in other areas.
While I do take on long term clients, most are more inclined to have me help them, then teach them how to care for it. The other thing that can be done is once a month and then you deal with it at a lower key level 3 weeks(say just water changes).
I did this for the CEO for Levi's here.
He does pretty well and no longer needs me.
T5 upgrade will help.
I'd go no more than 10 hours tops for light.
I think the CO2 may still be an issue, Controllers are only as good as delivery system they try to control, it does not imply they are really controlling CO2.
Seems like the tap is similar, we get it from the same water shed.
calihawker;28703 said:
All good with that
I've tried several different methods, the difficulty being the inability to store and heat/age 150+ gallons of water. I have a pump setup to drain the tank and a 55 gallon drum with a pump back into the tank. I just setup hot and cold taps into the drum to mix water to temperature as I'm pumping into the tank. Straight tap water with the addition of prime.
2 Rena xp3's, 1 xp4 with a magdrive 9.5 booster. Loaded with just sponges and some chemstars. Not sure of the flow rates but I'm starting to wonder if I have dead spots here and there.
4x40 watt T12 6500k for 12 hrs.
2x250 watt MH 4 hrs.
At the next light change cycle I will be upgrading to T5's
Currently: 60-70 Harlequin Rasboras, a dozen SAE's and a common Pleco.
Planned: 12-15 Discus, 15-20 Amano shrimp.
Honestly I think this is the area that I have had the least trouble with, if I can trust the drop checkers that is. I have a rex grigg style reactor, built a little bigger, on the out side of the xp4. The solenoid is hooked into an aquacontroller and controlled by ph. There are drop checkers on either end of the tank, both reading pale green to yellow. Fish are very happy and healthy.
Again, how well can I trust the drop checkers?
Agreed.
I'm about an hour east of Sacramento.
Thanks again Tom!
Steve
