EI Dosing on 16G Tank
PaulB
Subscriber
74
Melbourne, Australia
I have a 16g tank with a 55w AHS CF, Flourite substrate, pressurised Co2 via Tom's DIY internal reactor. I am currently dosing 1/8 tsp KNO3, 1/32 tsp KH2PO4 & 3ml Tropical plant nutrition liquid 3 time a week as per EI with a 50% weekly water change. Am i dosing enough macros & micros :confused: as i'm starting to see green spot algae appear on by glosso, crypts and anubias. Co2 comes on 1 hr before the light and is in the range of 25-30 ppm as indicated by a drop checker filled with a 4°Kh reference soluton.
88
When I had a 29 gallon tank, about twice the size of yours, I dosed 1/4 tsp of KNO3, but had to increase the dosage of KH2PO4 from 1/16 to 1/8 tsp to stop the GSA. This was GSA on the glass, not on leaves. You could try to double your KH2PO4 dosage and see if it helps. I'm now dosing 15 ml of Tropica plant nutrition liquid every other day in a 45 gallon tank, which would be 5 ml for a 16 gallon tank. So, either I am a bit high or you are a bit low. I went by the bottle directions in figuring out my dosage. (As I interpreted the directions.)
787
As long as the CO2 is good, then add more PO4 till it goes away.
/Tom Barr
