Ei dosing and low light with co2
Discussion in 'CO2 Enrichment' started by strat100z, Mar 9, 2011.
  1. strat100z
    strat100z Junior Poster
    Jan 8, 2011
    5:19 AM
    i have a 4x2x2 that is going to be a low light with co2 and just cant get my head around how much to dose,i no i should set my stall out and go full, half or whatever but would like to know what other people would do?
    The tank will also have wormcastings and kitty litter as substrate.
  2. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5:19 AM
    Why not start with 40-50% of basic EI for your size tank and see how that goes..
    Based on many other factors and your goals, you may dose only once or twice per week. The wormcastings will help long term in reducing the need for water column dosing.
    Hope this helps.
  3. strat100z
    Jan 8, 2011
    5:19 AM
    The goal for the tank is for low maintenance,so no stems at all,just ferns,bolbitus,anubias and a few crypts and maybe tennelus or hairgrass foreground with cyperus helferi in the background.
  4. Gerryd
    Sep 23, 2007
    5:19 AM
    I would dose full EI then as water column dosing seems to be vital with your plant selections.....
    You can always decrease slowly over weeks and if no adverse effect, lower a bit more..
    Try only twice per week say and see how it goes...
    Your tank sounds much like mine in terms of goals and plant species.
    Best of luck. Post some pics when you can.
  5. strat100z
    Jan 8, 2011
    5:19 AM
    Thank you for your help.
    all i need now is some manzanita to get it up and running,which is just about impossible in the uk.
  6. Tom Barr
    18,660
    600
    5:19 AM
    I do ship to the UK, but it's a fair amount to make it worth folk's while.
