Hi Tom
Following on from earlier discussions, I just want to make sure all is well with my dosing plans. I discussed in another thread using this Rexolin APN trace mix and you suggested adding some GH booster. I have since ordered and received some Barr GH Booster.(postage to Sydney far ouotweighed cost but still ahell of a lot cheaper than Equilibrium in the long run)
Rexolin APN
Chelate Trace Element Mix
Rexolin APN mix contains quality chelate forms of trace elements. It also contains Boron and Molybdenum as salts. Rexolin APN has been developed for the hydroponic industry, however it can be used in fertigation mixes for a wide range of crops. It has high solubility and can be used for foliar and soil applications.
Available in quantities from 1 kg to 25 kg's
Elements ratios:
Iron DTPA 6%; Manganese EDTA 2.4%; Boron 1.1%
Zinc EDTA 1.3%; Copper EDTA 0.25;
Molybdenum 0.25%; Cobalt EDTA 0.03% )
Here goes.
I have a 40g corner tank 50cm deep with 2.9w/g of flouro and T5 lighting. Co2 using drop checker at 4dkh is 30ppm. Tank has mainly tetras.ottos, siamensis and is pretty densely planted.
So 3x per week
1/2 teaspoon KNO3
1/8 teaspoon KH2PO4
1/8 teaspoon KS04
8 drops 3x/week ADA ECA iron supplement with NPK ( just to use it up )
1/8 teaspoon RExolin APN (on alternate days)
50-70% water change followed by 1 teaspoon of Barr's GH Booster and 1 teaspoon of baking soda and first course of macros
Should I do GH booster 1/2 tsp 2x a week?
Does this seem about right..Any suggestions would be great...
Also a question re lighting my corner tank. I have two 15w flouro T8's towards the back. Two 24w T5's in the middle and one T5 39w at the very front thus giving pretty good coverage. Being a corner does this equate to 2.9 w/g as it wood over a rectangular 40 g tank. Should I stagger the timing on the front 39w T5 to only 4 hours in the middle of the day?
Chris
Rexolin APN
Elements ratios:
Here goes.
So 3x per week
1/2 teaspoon KNO3
1/8 teaspoon KH2PO4
1/8 teaspoon KS04
Chris
