There is a lot of variables to fertilizing a tank. Read as much as you can on every aspect of fertilizers, co2 ,lights, plants, soils, filtration/circulation, and lots and lots on algae.
It's very rewarding having a planted tank, it's even more rewarding to learn and understand what your tank is telling you. You got this.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime" - maimonides
Hello friends
-I found a dose for 8 liter tank:
N 15ppm,P 4ppm,K 13,5ppm,CSM+B 0,4ppm
-earch not found CaSO4, MgSO4 doses in a week
-100% water Ro added Ca, Mg?
-50% water exchange must add Ca, Mg ppm weeks?
-Please help me
250ml bottle for micro
CSM+B 2g / each 2ml dose = .13ppm Fe
250ml bottle for macro
KNO3 6g / each 4ml dose = 7.35ppm NO3
KH2PO4 1g / each 4ml dose = 1.39ppm PO4
K2SO4 2g / each 4ml dose = 1.79ppm K
MgSO4 3g / each 4ml dose = .59ppm Mg
CaSO4 5g / each 4ml dose = 2.32ppm Ca
Add CaSO4 last in macro bottle after everything else dissolves.
Shake this 250ml container before drawing a 4ml dose since most of the CaSO4 will be in suspension in the solution.
It will dissolve once in the tank.
Please check these on an online calculator I ran the numbers rather quick.
You have also not described a target for KH and GH levels in your tank.
I'd recommend a KH of @ least 1dKH
Phishless
-thank you for sharing your experience
-thank you very much
-How much is the target for KH and GH is good for the tree?
-I don't know how much GH and KH goal is for the tree
-please help me
-Co2 test shows green: 20-30ppm Co2
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
