Hi all, I am new here and just started to dose using the EI method!
I use Prime during a water change, but also dose KNO3 (potassium nitrate). Prime from Seachem states that it removes chlorine and chloramine, and detoxifies nitrite, nitrate, and ammonia. Is it still in a state that my plants can readily take up or does Prime affect the nitrate negatively?
Typically I use a python setup to fill a 20g rubbermaid trash can with tap water. Then I treat the tap with prime, KNO3, KH2PO4, K2SO4. Then I cycle it with an underwater pump for about 5min before pumping into my tank.
Also a question about GH. I see that most of you all use GH boost with each water change, but due to natural evaporation my GH never seems to go down. It is at 4.5 degrees in my tank and my tap is 2.0, I do a water change weekly and do not add GH booster, or equilibrium, and my tank remains at 4.5. Is it due to the flourite or because I used to use flourish (which has small ammounts of Ca and other metals)?
