  1. Dismiss Notice
Eheim Filter
Discussion in 'Off Topic and Chat' started by inkslinger, Jan 15, 2018.
  1. inkslinger
    inkslinger Guru Class Expert
    Dec 15, 2007
    370
    11:17 PM
    Eheim 2262 Filter I know it will handle up to 500g but what is the lowest possible tank that can handle this filter? Would a 40g B be way to small? just asking.
  2. Kyalgae
    Kyalgae Lifetime Members
    Aug 25, 2016
    347
    234
    6:17 PM
    Here’s a video of it on a 125g. I can’t see it working on a 40gallon, but I’m just guessing from the video.
    Now if I had one to experiment with I would set up some inline static mixers in series to dissolve CO2. I wonder if that would work....it would really reduce the output.
  3. inkslinger
    Dec 15, 2007
    370
    11:17 PM
    I use 1 Clear Big Blue { Dimensions: 23-3/8" x 7-1/4" (594 mm x 184 mm) } Whole House filter with BIO balls and 1in intake/out put , with the Eheim 2262 I get 100% dissolve co2 . Have a pvc in the center go all the way down the bottom then the water will run up thru the bio balls and out .
    I have the co2 inter thru intake before it inters the reactor guess I can add a shut off ball valve and slow down the out put just a bit.
    #3 inkslinger, Jan 16, 2018
  4. inkslinger
    Dec 15, 2007
    370
    11:17 PM
    How about I change the pump , I have now is the Eheim 1262 pump 910 max flow rate . don't know if the hose size is the same but there is Eheim 1260 pump w/640gph flow rate and the Eheim 1250 pump w/320gph max flow rate. Would be nice to be able to drop the size down for a 75g or 90g tank and use my filter and run it thru my co2 whole house filter reactor.
