Edta Versus Dtpa
Steven Pituch
Dec 30, 2020
69
Hallettsville, TX
Hi all,
I have been dosing EI for a month. Liquid with traces and macros in separate bottles. The traces are pure Plantex CSM+B with 6.5% Fe, 65.4% EDTA. My new growth in my narrow leaf swords and micro swords is yellow. I tried overdosing K, P, and N separately (also to the roots in capsules) but the deficiency persisted. My KH is 14*and I try to keep the PH down to 7.2, 7.3 with CO2.
So I read that EDTA is not effective above PH = 7.0. So I purchased some DTPA/(11% Fe). DTPA is not effective above PH = 8.0, so I figured at 7.2-7.3 I should be making some Fe available to the plants. I added a pinch of DTPA/Fe to the water column in my three tanks. Two days later all the new yellow growth has turned a bright rich green. I think I have solved my first plant deficiency. I would think this knowledge would be generally known. It seems if you have hard water, you need to use DTPA/Fe.
So can I add the DTPAFe to my CSM+B trace solution? I’m afraid of the EDTA affecting the Fe.
I’ve seen trace elements for sale with both EDTA and DTPA.
Sincerely,
Steve Pituch
Steven Pituch
Dec 30, 2020
69
Hallettsville, TX
This is from one of the EDTA/DTPA/PH articles:
“ EDTA strongly holds iron in solution up to pH 6.0, but by pH 6.5, almost one-half the iron is precipitated, and by pH 7.0, almost none of the iron is available to plants. DTPA is an excellent iron source up to media pH 7.0; however, 60 percent of the iron is precipitated and unavailable by pH 8.0.”
Here is the link: https://www.canr.msu.edu/news/selecting_which_iron_chelate_to_use
Steve P
Steven Pituch
Dec 30, 2020
69
Hallettsville, TX
Based on the literature referenced by Pauld738, it seems to imply the DPTA/Fe and the EDTA/Fe will not influence each other. I guess the iron is actually bonded to the DTPA.
When I mix trace elements again in 500 ml of water, I will add enough DTPA/Fe to make .1 ppm Fe in my tanks. We’ll see how that works.
Steve
Reactions: Pauld738
