Boring very un-guru-ish type question...
Lots of E.Tenellus in my tank.
I'm doing full E.I. (and for those following my recent threads yes I am about to start rolling my own trace mix and additional DIY iron).
Substrate is 100% Seachem Flourite. Nothing else added to it.
E.Tenellus is doing ok, but not really "taking off". I'm increasing CO2 slowly etc etc.
Will adding anything around the roots of the E.Tenellus give them a boost in any way, or is this totally unecessary with full EI?
Would there be any benifit in me taking some of the 13% EDTA iron and mixing it with some clay or making iron concentrate ice cubes and shoving it deeply into the flourite here and there?
I'm trying to refresh my memory on this.
I'm pretty sure Tom has grown good carpetting plants using nothing but plain sand? Correct?
I'm also pretty sure that Tom said he only bothers with substrate enrichment as a "backup plan" should he miss an EI dose or something like that (although I'm not sure how fast plants can switch between root/follar feeding - i.e. do they need to adapt to it?).
I'm sure if Tom doesn't chime in, Bio, Nipat, Gerry et al (i.e. the "real gurus" unlike me) will............
Scott.
Scott.
