E I dosing amounts?? HELP!!
Discussion in 'Advanced Strategies and Fertilization' started by rs18alpha, Oct 11, 2017.
  1. rs18alpha
    rs18alpha Subscriber
    Feb 3, 2017
    132
    7
    6:03 AM
    I've read a lot articles on using the E I method. Some say to dose 5 days and rest 2 days. Some say to dose 7 days a week. I don't know which to try.
    The ones I've seen say to dose 15 mils of Mac ans Mic each dose.
    The amounts are Mac 79grams KNO3-22grams KH2PO4
    Mic 34grams CSM+B
    Question: Do I need to use any other ferts?
    Tank size 40 gal
    Moderate plant load
    30 or so Nano fish, 8 Amano shrimp. 6 Oto cats
    Moderate to high light
    Pressurized CO2
    Can some one give me good starting point with dosing amounts??
    Question: Should I dose 5 or 7 days a week?
  2. rs18alpha
    Feb 3, 2017
    132
    7
    6:03 AM
    Is any one out there? Any info would be helpful.
  3. burr740
    burr740 ~~ Lover of Micros ~~
    Staff Member Moderator
    Feb 16, 2015
    1,209
    907
    12:03 AM
    When you list the dosing in grams or teaspoons, people have to go to a calculator and run the ppm values for your tank size, bottle size and all that - before they even have a clue what you're talking about. That is asking a lot. And in this case, you didnt specify what size bottle you're using to mix the ferts - 500 ml, 250, 1000, etc.
    Truly Im not trying to sound like a jerk here, but lazy questions get lazy answers. :)
    You'll get much more accurate and faster advice if you list you're dosing in ppms. If you're unsure how to do that, then it's the first question you should have.
    Standard EI calls for roughly the following amounts, dosed 3x per week, with a 50% weekly water change.
    Macros
    7.5 ppm KNO3
    1.3 ppm KH2PO4
    7.5 ppm K (the above N and P adds around 5 ppm K already, some folks dont bother adding more, some do, most probably dont need it but it's a case by case thing)
    Micros
    .2 ppm Fe from csmb or whatever
    These amounts are not carved in stone, just a basic starting point that should be good for most high tech set ups.
    Dose macros back right after the water change. That's day one. Next day dose micros, next day macros, next day micros, and so on through the week. Skip dosing on the seventh day. Then the next day starts a new week off at day one with the water change.
    Not sure where you saw 5 days and skip 2, but you should dose both macros and micros 3x each between water changes, on alternating days. That's 6 days of dosing.
  4. rs18alpha
    Feb 3, 2017
    132
    7
    6:03 AM
    Thanks for the info. Sorry for the incomplete question.. I see what you mean.
    You've provided me with the info I need to start dosing with the E I method.
    I'll be using a 500 mil bottle so now I can figure out how much I need to mix and to dose to get the numbers.
    I appreciate your help!!
    burr740 likes this.
  5. rs18alpha
    Feb 3, 2017
    132
    7
    6:03 AM
    Does this sound right. According to the calculator,if I mix 66grams of KNO3 in 500 mil of water and dose 14mil at a time that will give me a total of 7.48ppm per dose.
    And if I mix 10 grams of KH2PO4 in 500 mil and dose 14 mil at a time that will give me a total of 1.29ppm per dose. Sound good?
    I haven't found a number on how much of the CSM+B to use so I'll have to keep looking for it.
  6. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    475
    498
    1:03 AM
  7. rs18alpha
    Feb 3, 2017
    132
    7
    6:03 AM
    These numbers are a lot different than the other calculators I've seen. So I still don't know which one to use??
  8. Phishless
    Jul 13, 2017
    475
    498
    1:03 AM
    Roll with it, it's estimative???
    You could download Zorfox calculator and test these numbers.
    I just ran them and they look good.
  9. burr740
    Feb 16, 2015
    1,209
    907
    12:03 AM
    Id use this one.
    http://rotalabutterfly.com/nutrient-calculator.php
    More fields will appear as you fill in the boxes
    It defaults to EI numbers. See beside the "I am calculating for" field it shows "Estimative Index". To target a specific ppm of something, change that to "dose to reach a target", then enter the desired ppm.
    For example, lets say you wanted to add an additional 2.5 ppm K using K2SO4. If you calculate for estimative index, it's going to give you a dose to hit 7.5 ppm. But you're already getting about 5 ppm from the other N and P, so you arent looking for the whole 7.5, so you'd calculate for 2.5 instead
    LRJ likes this.
  10. rs18alpha
    Feb 3, 2017
    132
    7
    6:03 AM
    Sounds good, thanks for the help people! I just got done reading a few articles and checking out the calculators. Now I've finally got it!! It all makes sense..
    Phishless likes this.
