The current iteration of this tank is not going to last long. The wife and kids are going out of town in two weeks and I'm taking the chance to do a breakdown and adding mts under my black diamond.
The Equipment
-standard 75gallon tank
-1 16" sbreeflight freshwater on the left
-1 24" fluval fresh and plant 2.0 on the right
-30 gallon diy sump
-dual diy pvc overflows
-Jaebo dct12000 return pump running through a 2"X24" rex griggs to an 1 1/4" submerged spraybar the length of the backwall. Ran at 50%
-15lb co2 tank
-milwuakee ma957 regulator (despite all the hate I love it, needS a better needle valve)
-black diamond blasting grit substrate with osmocote 00 root tabs (currently)
The Dosing:
-tap water comes out at 25-40tds 1-2gh and 0kh how I got so lucky I have no idea
-I dose another 2gh with NILOCG gh booster at water change
-micros are plantex csmb dose to .25ppm fe EVERY morning
-macros dosed to EI target levels EVERY evening
The Pictures: (just recovering from a huge chop)
The issues:
-Once the plant mass gets up I can dose 15ppm daily of N and still bottom out in the same light cycle
-Ive been upping all of my ferts to keep EI ratios whenever I need to up my Nitrates
-Eventually at the end of a grow out everything starts to stunt badly my guess is A:im overdosing ferts or B:im running out of GH and should actually test other than at water change C:my tank never has any noticeable KH
The Equipment
-30 gallon diy sump
-15lb co2 tank
The Dosing:
The issues:
