Dual Stage Regulators
Discussion in 'CO2 Enrichment' started by Left C, Nov 17, 2009.
  1. bsmith782
    bsmith782 Guru Class Expert
    Mar 14, 2007
    147
    2:39 PM
    I would not mind adding a Matheson to my collection but I have no use for one. Do you have a link to the ones available? I may snag a few to hold on to for future use.
    Maybe someone could answer this? I have a Victor and a Concoa. I cant relly tell a difference between the two as far as accuracy and reliability. Both have been preforming flawlessly for the past few years. Anyone know really which is really the best or worst out of the DSR's that we are using?
  2. Left C
    Left C Lifetime Members
    Sep 26, 2005
    2,510
    2:39 PM
    Here's some Matheson's: http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A4583&rt=nc&_nkw=matheson+regulator&_ipg=200&_trksid=p3286.c0.m14.l1514
    VWR is another good two stage regulator: http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=VWR+regulator
    I'll always pick the Victor line over all others. But that's just me. It isn't based on any tests or studies. I just like them.
    Some of the other brands look weird. Like this one. It looks like something Flash Gordon or Buck Rodgers would use: http://cgi.ebay.com/AGA-Gas-Regulator-Type-CB-200-2-6C-250-3000-4-85-PSI-/290509585053?pt=LH_DefaultDomain_0&hash=item43a3b87a9d
  3. DukeNJ
    DukeNJ Lifetime Charter Member
    Sep 18, 2009
    146
    2:39 PM
    Hehe left C. I love that one...because it's different...and shiny. :)
    I assume any name brand dual stage is engineered well beyond our applications needs and would perform well for a lifetime. Is that generally a safe assumption?
  4. S&KGray
    S&KGray Guru Class Expert
    Nov 18, 2009
    236
    2:39 PM
    That is a nice AGA (re-branded Linde in this case) regulator.
    I would say yes if its a Concoa, Harris, Linde, Matheson, Smith, Victor, or any of the previous re-branded. I may have missed some other well-known brands/manufacturers and the list is in alphabetical order as to not show favoritism. lol
  5. Matt F.
    May 30, 2009
    2,319
    2:39 PM
  6. Matt F.
    May 30, 2009
    2,319
    2:39 PM
    #1746 Matt F., Dec 9, 2010
  7. S&KGray
    Nov 18, 2009
    236
    2:39 PM
    +1 nice Victor Rodent Regulator, is it single or dual stage? :p
  8. instantcrow
    instantcrow Prolific Poster
    Jun 13, 2010
    32
    2:39 PM
    I tightened up some connections and now my bubble rate is constant and the pressure remains constant while the solenoid is open (10psi). However, when the solenoid closes, the pressure slowly rises to about 12.5psi. I think this is due to less volume and flow thereby causing an increase in low pressure side. But I thought dual stage regs were designed to provide constant output flow regardless of downstream flow. Could this be a leak? I now this is obsessive, I'm just curious.
  9. Matt F.
    May 30, 2009
    2,319
    2:39 PM
    a 2 psi difference in normal when the solenoid closes. It's the difference between flow and static pressure. This does not affect the constant outlfow rate of gas, for the regulator is delivering a constant pressure when the valve is open. When the solenoid opens, the pressure goes right back down to where you set the low pressure gauge.
    According to victor techs this is normal. what would be abnormal is if your low pressure crept up more than about 3 psi 15 minutes after your solenoid shuts off. this would suggest that the diaphram(s) are shot and the regulator needs a rebuild, which is not that big a deal.
    so a slight immediate increase in psi on the low pressure side is normal once the solenoid shuts off. It the low pressure increases 15 minutes or more after the solenoid shuts, there is a problemo.
    #1749 Matt F., Dec 11, 2010
  10. bsmith782
    Mar 14, 2007
    147
    2:39 PM
    Remember when MRmotercycles was selling the nice victors and concoas for ~$45? I wonder is he is still around and has anything nice?
    If the V reps say its fine then I believe them but I have never, ever witnessed my pressure rise at all during shut off.
  11. Left C
    Sep 26, 2005
    2,510
    2:39 PM
    He started selling them for $19.30 shipped, I believe. The good ole days.
    Several months back someone said they saw some regs on ebay that he was selling. I emailed him and I never heard back.
  12. Matt F.
    May 30, 2009
    2,319
    2:39 PM
    bsmith-
    My brand new (from the factory) Nuaire/Victor VTS253A-1993 increased working pressure by .50 psi when the solenoid shuts off. I had a used Nuaire VTS253A-1993 that jumped a whole 2 psi.
    This concerned me, so I contacted Thermadyne (aka Victor) and the tech assured me that a slight increase in working pressure is totally normal. The solenoid shuts off and changes from flow to static pressure. My low pressure gauges goes back to exactly where I set it once the solenoid opens again.
    I had a VTS253B-320 that did this, too. So I wouldn't be too worried about it.
    If the pressure increases after the initial immediate bump in psi at shut-off, then it's time for new diaphrams, etc.
    What psi range gauges do you have on your regulator(s)?
  13. Matt F.
    May 30, 2009
    2,319
    2:39 PM
  14. Left C
    Sep 26, 2005
    2,510
    2:39 PM
  15. Matt F.
    May 30, 2009
    2,319
    2:39 PM
    Bout time you got one.
    #1755 Matt F., Dec 11, 2010
  16. Left C
    Sep 26, 2005
    2,510
    2:39 PM
  17. barbarossa4122
    barbarossa4122 Guru Class Expert
    Dec 29, 2009
    975
    2:39 PM
    Hi Left C,
    What do you do with so many regulators ?:)
    Btw, I only have three but, 2 are in use.
  18. Matt F.
    May 30, 2009
    2,319
    2:39 PM
    The female regulator cga threads are good on that one. All you need is a 320 stem/nut and you're in business. I asked the seller to post the pics of his remaining red knobs last night. They are in great shape. Even the one you got.
  19. Left C
    Sep 26, 2005
    2,510
    2:39 PM
    They are in hiatus right now. :)
    I hope that this red knobber's inlet threads are in good shape. Take a look at the next to last and last picture. The threads may be galled.
  20. Left C
    Sep 26, 2005
    2,510
    2:39 PM
    Thanks!!! That's good news.
    I didn't see this post when I just posted.
