Dual Stage Regulators
Discussion in 'CO2 Enrichment' started by Left C, Nov 17, 2009.
  1. pat w
    pat w Member
    Nov 4, 2009
    462
    4:09 PM
    And where have I seen that Victor 2-Stage Regulator CO2 rig they're using as an image on their website? Hmmm.
    You're Famous.
    Pat
  2. S&KGray
    S&KGray Guru Class Expert
    Nov 18, 2009
    236
    4:09 PM
    I am planning on doing this also because I already have a couple of 1/4" MPT x 1/8" FPT reducer bushings laying around.
  3. Left C
    Left C Lifetime Members
    Sep 26, 2005
    2,510
    4:09 PM
    Your suggestion will work just fine. Strength shouldn't be an issue.
    Here's what I would use for a regulator with it's output at 9 o'clock. I'd use a 1/4" x 1/8" reducing bushing and then a 1/8" hex nipple.
    [​IMG]
    1/8" hex nipple
    [​IMG]
    ____________________________________________________________________
    Using a regulator with its output at 7 o'clock, there are several ways to do it. Coming out of the regulator, you could use any of these reducers:
    1/4" x 1/8" reducing nipple
    [​IMG]
    1/4" x 1/8" reducing male elbow
    [​IMG]
    [​IMG]
  4. Left C
    Sep 26, 2005
    2,510
    4:09 PM
  5. Left C
    Sep 26, 2005
    2,510
    4:09 PM
    I told them that quite a few people are building regulator assemblies for aquarium use now. I sent them the link to this thread as an example. I didn't know that they were going to use my Avatar.
  6. Jowlz
    Jowlz Junior Poster
    Nov 16, 2010
    26
    4:09 PM
    I'm curious. Did freshwater systems carry the burkert solenoids before getting this batch of Buna seal units? I ask because I ordered a solenoid and din plug from them yesterday and am wondering if I will be getting the new one or will be getting an older style....
  7. Matt F.
    May 30, 2009
    2,319
    4:09 PM
    I just re-did this regulator with more aesthetically pleasing fittings. The 3" nipple comming out of the regulator was too long when the coupling was attached. It looked unbalanced.
    I replaced it with a 2" nipple. Everything looks more compact and tight.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  8. Matt F.
    May 30, 2009
    2,319
    4:09 PM
    Before: (3" nipple)
    [​IMG]
    After: (2" nipple)
    [​IMG]
  9. stuffrider147
    stuffrider147 Prolific Poster
    Sep 27, 2010
    61
    4:09 PM
    I would also like to know the answer to this question..
  10. stuffrider147
    Sep 27, 2010
    61
    4:09 PM
    Yes, it does look much better now, nice work!
  11. Left C
    Sep 26, 2005
    2,510
    4:09 PM
    To my knowledge, they never carried the 6011 Viton seal model. They do carry other Burkert products, though: http://www.freshwatersystems.com/search2.aspx?page=1&keywords=Burkert&Search=Search
  12. Jowlz
    Jowlz Junior Poster
    Nov 16, 2010
    26
    4:09 PM
  13. Left C
    Sep 26, 2005
    2,510
    4:09 PM
    You can forget the Sir part. I might deserve a good kick.
    Be sure to order one of the two LED cable plugs along with your solenoid.
  14. Matt F.
    May 30, 2009
    2,319
    4:09 PM
    Are they asking about different buna-n "batches" of solenoids or "the older version" meaning Viton seal versus Buna-N.
    I don't think there are any "old batches" of BUna-N solenoids out there. Prior to Freshwater Systems carrying them, they were only special order with a 5-7 week lead time.
    If you're worried about having a Viton unit, it's easy to tell: they are a different part number.
    #1654 Matt F., Nov 18, 2010
  15. 2112
    2112 Prolific Poster
    Aug 22, 2010
    86
    4:09 PM
    Thank you for pointing that out to me. I skimmed over it pretty quickly and don't see how I missed that they were both LEDs. Duh.
  16. Left C
    Sep 26, 2005
    2,510
    4:09 PM
    I think that I might have to eat some crow because of something that I told you. So, take back the Duh for the time being. I might need to use it. :eek:
  17. Orple
    Orple Prolific Poster
    Oct 5, 2010
    42
    4:09 PM
    Out of curiosity, is there any generally accepted wisdom here about what kind of tubing adapters to use? I wasn't expecting there to be such a wide variety. It looks like most people use the one that comes stock at the end of the JBJ bubble counters, but I'll be putting an adapter on to my Ideal needle valve and then running tubing to my DIY bubble counter. I've been looking through the McMaster-Carr sight, and there are like 6 different kinds... can anyone narrow down the alternatives for me?
  18. 2112
    Aug 22, 2010
    86
    4:09 PM
    [/duh] *status pending*
  19. Left C
    Sep 26, 2005
    2,510
    4:09 PM
    What is the inner diameter of the tubing that you will be using?
    If the ID is 1/8" and male thread that screws into the Ideal needle valve is 1/8" NPT, you can use either brass or plastic adapters.
    [​IMG]
    #1659 Left C, Nov 19, 2010
  20. Orple
    Oct 5, 2010
    42
    4:09 PM
    Heh, I actually haven't figured out the dimensions of the tubing yet; I'm still reading up on that (really not sure why something so supposedly simple as tubing needs to be so complicated; I still can't figure out what the final word is on that--size, material, etc.). But I figured I'd get the brass figured out and adjust the tubing dimension of the fitting once I decided on the tubing.
    BTW, where is the picture you posted from? There's nothing like that on McMaster-Carr; they only have a MPT with a tubing stem (which looks like a post with two channels across it). Do you find the barbed connectors generally better than the screw-on connectors at the top of the JBJ's?
    #1660 Orple, Nov 19, 2010
