Dual Stage Regulators
Left C
Sep 26, 2005
2,500
69
Burlington, NC
nipat;43353 said:
I've tried to look at the diagram several times but still don't know why lower input pressure creates higher output pressure (in single stage regs) which causes EOTD. :confused:
Inlet pressure aids in sealing which is reduced as pressure decreases as well.
S&KGray
Nov 18, 2009
236
Garden Island
Is is possible to connect directly to CO2 tubing from a Swagelok tubing connector? Instead of adapting to 1/8 npt and then using a 1/8 npt hose barb fitting?
Left C
Sep 26, 2005
2,500
69
Burlington, NC
It is as long as you are using 1/8" OD tubing for the 1/8" fittings. (same fitting size to same OD)
http://www.swagelok.com/search/find_products_home.aspx?SEARCH=/id-10000009/type-1
Swagelok even has tubing to tubing adapters.
brass: http://www.swagelok.com/search/product_detail.aspx?part=B-200-6
nylon: http://www.swagelok.com/search/product_detail.aspx?part=NY-200-6
SS: http://www.swagelok.com/search/product_detail.aspx?part=SS-200-6CP
eiginh
Sep 17, 2009
SWAGELOK STAINLESS STEEL FITTINGS
Do I need all this in order to use a Victor 253a-1993 with a clippard solenoid? I'm going stainless for the look...
Stainless Steel 1/4" MPT x 1/8" MPT Hex Reducing Nipple ( SS-4-HRN-2 ) $6.15
Stainless Steel 1/4" MPT x 1/8" FPT Reducer Bushing SS-4-RB-2 $5.74
Stainless Steel 1/8" MPT Hex Nipple ( SS-2-HN ) $4.72
Stainless Steel 1/4" MPT x 1/4" MPT Elbow SS-4-ME $14.05
Stainless Steel Tubing Connector, 1/8" MPT x 1/8" ID Tubing SS-2-HC-1-2 $5.64
Stainless Steel Tubing Connector, 1/8" FPT x 1/8" ID Tubing SS-2-HC-7-2 $12.71
Left C
Sep 26, 2005
2,500
69
Burlington, NC
Where's the links? Now I have to look them all up. I'll be back in a little bit.
Left C
Sep 26, 2005
2,500
69
Burlington, NC
You have some parts wrong.
List them in order starting at the regulator and working all the way to the tubing.
You have too many male 1/4" parts to tell what you are actually trying to do.
Left C
Sep 26, 2005
2,500
69
Burlington, NC
Swagelok Stainless Steel 1/4" and 1/8" Pipe Fittings
Ripe Reducers
SS-4-HRN-2 Hex Reducing Nipple, 1/4 in. Male NPT x 1/8 in. Male NPT Price: $6.15
SS-4-RB-2 Reducing Bushing, 1/4 in. Male NPT x 1/8 in. Female NPT Price: $5.74
SS-4-RA-2 Reducing Adapter, 1/4 in. Female NPT x 1/8 in. Male NPT Price: $8.92
Pipe Elbows
SS-2-E Elbow, 1/8 in. Female NPT Price: $15.99
SS-4-E Elbow, 1/4 in. Female NPT Price: $18.56
SS-2-ME Male Elbow, 1/8 in. Male NPT Price: $13.33
SS-4-ME Male Elbow, 1/4 in. Male NPT Price: $14.05
SS-2-SE Street Elbow, 1/8 in. Female NPT x 1/8 in. Male NPT Price: $16.40
SS-4-RSE-2 Reducing Street Elbow, 1/4 in. Female NPT x 1/8 in. Male NPT Price: $21.43
SS-4-SE Street Elbow, 1/4 in. Female NPT x 1/4 in. Male NPT Price: $18.56
Nipples
SS-4-CN Close Nipple, 1/4 in. Male NPT Price: $5.64
SS-2-CN Close Nipple, 1/8 in. Male NPT Price: $4.10
SS-4-HLN-1.50 Hex Long Nipple, 1/4 in. Male NPT, 1 1/2 in. Length Price: $6.77
SS-4-HLN-2.00 Hex Long Nipple, 1/4 in. Male NPT, 2 in. Length Price: $8.51
SS-2-HLN-1.50 Hex Long Nipple, 1/8 in. Male NPT, 1 1/2 in. Length Price: $7.69
SS-2-HLN-2.00 Hex Long Nipple, 1/8 in. Male NPT, 2 in. Length Price: $8.20
SS-4-HN Hex Nipple, 1/4 in. Male NPT Price: $6.05
SS-2-HN Hex Nipple, 1/8 in. Male NPT Price: $4.72
Left C
Sep 26, 2005
2,500
69
Burlington, NC
Barbed Hose (Tubing) Fittings
SS-2-HC-1-2 1/8 in. Male NPT, 1/8 in. Hose ID Price: $5.64
SS-2-HC-1-4 1/4 in. Male NPT, 1/8 in. Hose ID Price: $8.61
SS-2-HC-7-2 1/8 in. Female NPT, 1/8 in. Hose ID Price: $12.71
SS-2-HC-7-4 1/4 in. Female NPT, 1/8 in. Hose ID Price: $14.35
Tubing Adapters
SS-4-TA-1-4 Male Tube Adapter, 1/4 in. Tube OD x 1/4 in. Male NPT Price: $6.05
SS-2-TA-1-2 Male Tube Adapter, 1/8 in. Tube OD x 1/8 in. Male NPT Price: $6.26
SS-4-TA-1-2 Male Tube Adapter, 1/4 in. Tube OD x 1/8 in. Male NPT Price: $5.54
SS-2-TA-1-4 Male Tube Adapter, 1/8 in. Tube OD x 1/4 in. Male NPT Price: $7.08
SS-4-TA-7-4 Female Tube Adapter, 1/4 in. Tube OD x 1/4 in. Female NPT Price: $9.64
SS-2-TA-7-2 Female Tube Adapter, 1/8 in. Tube OD x 1/8 in. Female NPT Price: $7.69
SS-4-TA-7-2 Female Tube Adapter, 1/4 in. Tube OD x 1/8 in. Female NPT Price: $7.90
SS-2-TA-7-4 Female Tube Adapter, 1/8 in. Tube OD x 1/4 in. Female NPT Price: $9.02
Left C
Sep 26, 2005
2,500
69
Burlington, NC
A really simple design is to use:
- from regulator to solenoid: SS-4-HRN-2 Hex Reducing Nipple, 1/4 in. Male NPT x 1/8 in. Male NPT Price: $6.15
- Clippard solenoid (1/8" female ports)
- from solenoid to needle/metering valve: SS-2-HN Hex Nipple, 1/8 in. Male NPT Price: $4.72
- from needle/metering valve to 1/8" ID tubing: SS-2-HC-1-2 1/8 in. Male NPT, 1/8 in. Hose ID Price: $5.64
You will have something like either of these two with this simple design.
eiginh
Sep 17, 2009
I got the list from the pm you sent me on pt. Thanks for putting that out though! that really helps. Btw is the last post the recommendation for zip tieing the meter valve?
jonny_ftm
Mar 5, 2009
821
Not a so good idea to mount that way, you loose the real benefit from Swagelok tubing adapters: no leaking fitting
here it is:
The circled part consists of:
B-6M0-1-2
B-6M5-4M
You get a leak free clean setup
jonny_ftm
Mar 5, 2009
821
eiginh;43404 said:
Do you mean the zip tieing way is the bad way or what Left C suggested?
Both,
using the parts I mention you get a leak free setup and no torsion on the tubing while you lock the screw. Look their site for the way the locking is done. It's not easy to understand but very precise. You have to turn the screw 1 and 1/4 turn exactly
nipat
May 23, 2009
665
Ah, I think I see. For two stage regs, the increase of the pressure after the first stage
will aid in sealing at the second stage, clever.
Thanks.:)
