I decided to upgrade both my DSR (Dual Stage Regulators) due to the fact that one of my custom chrome plated JBJ bubble counters failed. The check valve was letting mineral oil into the Swagelok check valve just below it. I added the Swagelok check valve just in case this happened, so no damaged resulted from this failure. The same might not be said if you are running a JBJ bubble counter without another check valve just beneath.
Parts used:
Tube 4mm/6mm (ID/OD)
Swagelok SS-6MO-1-2 (male connector)
Swagelok SS-6M5-4M (insert for tubing)
Swagelok SS-2-HCG (hex coupling)
ADA bubble counter (in-line)
Victor SGT 500:
Here are some pictures of the unit before conversion:
Let the conversion begin:
Parts used:
Victor SGT 500:
