DSM and Cyanobacteria
Discussion in 'General Plant Topics' started by tirtha1979, Jan 31, 2011.
  1. tirtha1979
    tirtha1979 Prolific Poster
    Jul 10, 2007
    45
    5:15 AM
    I am growing few plants using DSM method like HC, Staurogyne, hydrocotyle umbellata. Plants are growing fine but after first 1-2 weeks I can see Cyanobacteria patches on the substrate. And within a month the complete substrate is getting covered by a layer of BG algae. Using brand new AS II as substrate. Source of light is T5HO or indirect Sunlight or direct sunlight for 2-3 hours in different setup.
    As far as I know, Cyanobacteria comes when there is very less Nitrate or no flow. But these are not, seems to be a reason in dry start.
    Any idea how to get rid of this problem? Anything am I doing wrong? Please share your thoughts.
    regards,
    Tirtha
  2. ibanezfrelon
    ibanezfrelon Guru Class Expert
    May 18, 2010
    205
    5:15 AM
    maybe you have too much water in that emersed start? can you post a photo?
  3. tirtha1979
    Jul 10, 2007
    45
    5:15 AM
    Sorry for the late reply. That might be the reson. I keep a very thin of water layer always on the substrate. Will avoid it. Sorry for not having a picture handy.
  4. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5:15 AM
    The substrate should be moist but no standing pools of water....the environment needs to be humid as well so many folks add too much water to assist with humidity.
    However, too much water is not good:)
    If the water pools anywhere (say a depression in substrate) I would remove some from that spot.
    Hope this helps.
