Hi Guys,
Just wondering if there is anybody on here that knows a bit about 'thermal protection' for circulation pumps?
I have an Ocean Runner OR-2500 pump which has 'thermal protection'. I am trying to understand exactly how this works.
According to the handbook that came with it, if the impellor gets stuck, this thermal protection mechanism will kick in.
So, I understand that if the impellor gets stuck the pump will start to heat up and the mechanism will kick in; but what exacly does the mechanism do when it kicks in? I assume that the pump will simply stop running, and will only resume running when the power is turned off and back on again? Or do you have to wait several minutes for it reset itself after turning the power off?
Along the same lines, if the pump were to run dry, shouldn't the thermal protection mechanishm also kick in?
I read something in another forum saying something about the thermal protection mechanism only working for jammed impellors but not for dry run - I don't understand the difference? Surely the designers of these pumps would forsee dry running as a likelyhood and therefore build in protection mechanisms?
Scott.
Scott.
