Dry Ferts!!!!!
Discussion in 'Trades, swaps, sales' started by nilocg, Jul 17, 2012.
  1. nilocg
    nilocg Prolific Poster
    Jul 29, 2010
    70
    12:38 AM
    Here is a picture of the new packaging for all of the dry ferts:
    [​IMG]
    Dry Ferts- Ala Carte
    Potassium Nitrate (KNO3)- $3/lb
    Mono Potassium Phosphate (KH2PO4)- $5/lb
    Potassium Sulfate (K2SO4)- $3/lb
    Miller Microplex- $9 per 1/2lb or $17/lb
    Plantex CSM+B- $12/lb
    Iron Chelate 10% DTPA- $10 per 1/2lb, $18/lb
    Iron Chelate 13% EDTA- $9 per 1/2lb $8/ half lb, $14/lb
    Magnesium Sulfate (MgSO4)- $2.50/lb
    Manganese Sulfate (MnSO4)- $8/ half pound
    Calcium Nitrate (CaNO3)- $2.50/lb
    Calcium Sulfate (CaSO4)- $3/lb
    GH Booster- Contains 3:3:1(K2SO4:CaSO4:MgSO4)- $6/lb
    -Shipping will be $6 no matter how much is ordered, unless otherwise noted-
    Package Pricing
    NPK + CSM+B Package- $20 shipped
    1lb KNO3, 1/2lb KH2PO4, 1lb K2SO4, and 1/2lb CSM+B
    Add 1/2lb of Iron Chelate 13% for $7 or 1/2lb Iron Chelate 10% for $8.50
    NPK + microplex Package- $22 shipped
    1lb KNO3, 1/2lb KH2PO4, 1lb K2SO4, and 1/2lb miller microplex
    EI based NPK + CSM+B - $22 Shipped
    2lb KNO3, 1/2lb KH2PO4, 1/2lb K2SO4, and 1/2lb CSM+B
    EI based NPK + microplex Package- $24 Shipped
    2lb KNO3, 1/2lb KH2PO4, 1/2lb K2SO4, and 1/2lb Miller Microplex
    Micro/Macro Mix- $10/pound $18 for two pounds plus $6 shipping NOW IN STOCK
    Contains:
    Miller Microplex
    Liquid NPK + M
    Dosing for full EI levels is 1 pump of each bottle per 10 gallons 3x per week.
    For lower light/lower tech tanks dosing at 1 pump per 20 gallons 3x per week.
    For example: For a 20 gallon higher light tank would be as follows-
    2 pumps of the micros per day Monday, Wednesday and Friday.
    2 pumps of the macros per day Tuesday, Thursday and Saturday.
    50% week water change is suggested on the 7th day per EI guidelines followed by addition of the GH booster of your choice(I have some for sale below in the dry ferts section).
    Bottles are 16oz each.
    This will last more than 41 weeks on a 20 gallon tank dosing 3x per week.
    I am asking $29 shipped
    [​IMG]
    DIY EI Liquid Ferts
    Want to dose ferts but the cost of liquid ferts is too expensive???
    Dont want to go through the hassle of mixing dry ferts yourself???
    Then this is for YOU!!!!!!
    What you get- 2x 500ml dosing bottles(1x Micros, 1x Macros)
    2 complete refill packets( so you are essentially getting enough to make 1500ml of both micros and macros)
    Cost- $28 shipped
    It will be shipped without water, all you will need to do is add 500ml of RO water to each bottle. When the solution in each bottle runs out, simply add the refill packet to the appropriate dosing bottle and add 500ml of RO water and you are good to go again.
    Dosing Instructions:
    Add 5ml per 20 gallons of water for each the micro and macro 3x per week on alternating days per the EI dosing instructions.
    How long will this last me??
    20 Gallon tank- roughly 2 years
    40 gallon tank- roughly 1 year
    80 gallon tank- roughly 6 months
    and so on...
    Special thanks to WETS dosing calculator:
    Warning: Micro solutions will sometimes grow mold, to prevent this you should either refrigerate it or add 10ml excel to the solution
    Concentrations(as per wets calculator):
    Micro-
    B- 0.09ppm
    Cu 0.01ppm
    Fe 0.50 ppm
    Mg 0.11 ppm
    Mn 0.14 ppm
    Mo 0.0038 ppm
    Zn 0.03 ppm
    dGH 0.02
    Macros:
    N- 7.5ppm
    P- 1.3ppm
    K- 4.27ppm
    PPS-Pro Liquid Ferts
    PPS-Pro style liquid fertilizer- $27 shipped
    Includes:
    -2x 500ml dosing bottles
    -Pre-measured micros and macros, enough to dose 5000 gallons of tank water.
    -Also comes with set of refill packets
    Additional refill Packets are $6 per set.
    The ferts will come already in the dosing bottle, simply fill the bottle with 500ml of RO water and you are ready to go.
    Dose 1ml per 10 gallons of water of each micro and macro ferts each day prior to lights coming on.
    NEW MTS/EI/CLAY Capsules-
    50 [HASHTAG]#000[/HASHTAG] capsules for $14 shipped
    These Comprise of:
    75% Mineralized Top Soil
    25% EI+Clay formula(16 parts Red Clay, 8 parts CSM+B, 2 parts Potassium Sulfate, 2 parts Magnesium Sulfate, 0.5 part Potassium Nitrate)
    OSMOCOTE+CAPSULES
    For sale are 00 sized capsules filled with Osmocote Plus. I am selling them for the cheapest I have seen them sold. Get them while they last.
    The capsules are-
    -BSE Free Certification-
    -Gelatin Capsules -
    - Halal Certificate -
    -Kosher Certification -
    Options-
    Prices include first class shipping - add $3 for Priority
    25 - $5
    50 - $8
    75 - $10
    100 - $11
    150 - $12
    200 - $17
    300 - $20
    #1 nilocg, Jul 17, 2012
  2. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Everything is still available
  3. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Plenty left
  4. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Bump for more
  5. beedee
    beedee Junior Poster
    Oct 24, 2012
    21
    12:38 AM
    i wont be flooding my new tank for 1.5 months or so, but am thinking of dosing dry ferts. (please see my signature for my tank journal).
    im thinking of buying your package:
    do you know what a good dosing regiment would be for that tank once it is carpeted and all filled in?
  6. nilocg
    Jul 29, 2010
    70
    12:38 AM
    I would suggest dosing as follows,
    10-20 Gallons
    1/8 tsp KNO3 3x a week
    1/32 tsp KH2PO4 3x a week
    1/32 tsp K2SO4 3x a week
    1/32 tsp (2ml) traces 3x a week
  7. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Bump, still got plenty, cheapest prices guaranteed.
  8. mathman
    mathman Guru Class Expert
    Mar 8, 2011
    260
    12:38 AM
    I would like two pounds of each if you have any left.
    How are they packaged?
  9. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Have everything in stock.
  10. Matt F.
    May 30, 2009
    2,319
    12:38 AM
    Where are you located?
  11. nilocg
    Jul 29, 2010
    70
    12:38 AM
    I am located in oregon.
  12. Mint
    Mint Junior Poster
    May 3, 2013
    12:38 AM
    I am interested in buying the NPK + CSM+B Package for $20.
  13. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Thanks for your order. Still have plenty left.
  14. Moby
    Moby Prolific Poster
    Dec 15, 2011
    32
    12:38 AM
    still available? If yes I would like to buy
    2lbs of KNO3 6$
    1 lb of KH2PO4 5$
    1/2 lb of Plantex CSM+B 6$
    1/2 lb of Iron chelate 13% 8$
    Shipping 6$
    Total 31$
    Let me know if available and a payment method.
    Moby.
  15. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Yes everything is still available, PM sent.
  16. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Bump for more
  17. newportjon
    newportjon Junior Poster
    Mar 22, 2011
    6
    12:38 AM
    Still available?
    I'm interested in ordering a package today, if possible.
  18. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Still have plenty
  19. nilocg
    Jul 29, 2010
    70
    12:38 AM
    Bump for more
  20. scoupland
    scoupland Lifetime Members
    Sep 22, 2011
    12:38 AM
    Do you carry ferrous gluconate?
