I have a 240g acrylic 8x2x2' tank that I'm getting ready to fire up soon. The plan for this is to be fairly high tech with pressurized CO2, good lighting, filtration, etc. The tank is drilled on the bottom with 1.5" for drains and 1" for return (1 set each towards each corner). I had the 1.5" already set up for PVC to a sump, and was going to run a MAG 18 or 24 for the return. During the couple of months (before top bracing popped off corner) I was testing/fine tuning this setup I was having difficulty getting what I felt was enough CO2 into the tank. I was originally feeding the CO2 through some diffusors into a MAG 18. My question is am I better off maybe sticking with canister filters to minimize CO2 loss? If I stick with a sump, should I be setting up my CO2 to diffuse into the tank under a couple of Koralia or something like that? I have a could or 2" Atomic diffusors that work nice in my 125g. I also have two Eheim 2078's that I can fire up as well. I was getting pretty frustrated with the sump although a lot of people swear by them for big tanks. Any ideas would be greatly appreciated.
