I made a post a month or so ago and got excellent advice about DIY substrate, lights, etc. My tank is now on its stand, with a DIY cork bark background (looks so cool!) and filled with some gorgeous driftwood that I collected myself. I have 100 lbs of Turface MVP gray, some peat, and I am expecting some HC, some Glosso, and some Lobelia cardinalis 'short form' from Aqua Botanica. My lights should be on their way (39 Watts x 8 T5HO) as well as ferts:
* Micros -
o Plantex CSM + B
* Macros -
o Potassium Nitrate (KNO3)
o Mono Potassium Phosphate (KH2PO4)
o Potassium Sulfate (K2SO4)
I have been instructed from a new friend at a semi local Plant club (SWOAPE) as follows:
"Next, fill up a 5g bucket with water and mix in 1.5 tsp of KNO3 and 0.25tsp of KH2PO4 into the water in the bucket. You can add some K2SO4 if you have it but our water supply here in Dayton (and probably in KY) is already pretty high in K so it probably isn't needed. This is a highly concentrated amount of fertilizers considering the volume of the 5g bucket and should give you about 10ppm of NO3, 2ppm of PO4 and 7ppm of K based on the total water volume of your tank."
I will put some mulm in with the peat and Turface before all of this. This all sounds good to me and I have been reading like crazy about EI fertilization and PPS methods as well as non-CO2 methods. I have also read all I can find about growing HC and glosso emersed.
I will be using pressurized CO2 and some method of fertilization, which I have some time to decide on. I am posting here just to kind of let y'all know what I am up to and if I am about to do anything particularly horrible? I am slightly concerned about the ferts in the substrate at such a high concentration and whether or not to add K2SO4, but also try to listen to good advice when I get it! SWOAPE has been very helpful and invited me to join their club! I expect the HC/glosso to grow emersed for as long as 8 weeks while I assemble my filter and CO2 system.
Any comments would be appreciated. I have been learning bunches: just enough to be really dangerous now that I will own plants, lights AND chemicals! I have been so busy reading that I have not posted! Thanks for any thoughts.
* Micros -
o Plantex CSM + B
* Macros -
