Dosing iron sulphate and API water conditioner
Discussion in 'Aquatic Plant Fertilization' started by tiger15, Aug 12, 2017.
  1. tiger15
    tiger15 Member
    Aug 12, 2017
    224
    78
    4:24 PM
  2. slipfinger
    slipfinger Article Editor
    Jul 23, 2016
    355
    470
    4:24 PM
    I don't think 9.8% chelating agent would be enough to keep the iron around long enough for the plant to grab any of it. Fo example 13% Fe EDTA has 68% chelating agent.
  3. tiger15
    tiger15 Member
    Aug 12, 2017
    224
    78
    4:24 PM
    I don't know the % EDTA you refer to has the base as the API EDTA, so we may be comparing apple to orange. The API is in liquid form with 30.2 % accompanying sodium thiosulfate. Is your in dry or liquid form and how much do you dose. The EDTA is there to remove heavy metal, so consensus advice says that water conditioner should not be dosed at the same time with micro nutrients. So it depends on how much you dose on each to determine the level of chelating. I don't know the math and if someone has tried dosing FeSO4.
  4. slipfinger
    Jul 23, 2016
    355
    470
    4:24 PM
    Not to sure why you would even want to mess around with FeSO4. Yes its cheap, but so are other forms of Fe be it Fe EDTA or DPTA especially in the amounts we dose. Plus the math is already done for you.
    I purchase dry Fe DTPA and mix it in my own solution which I dose every other day at .1ppm. The reason I use DTPA is because it is said to be more stable at my ph range, 4 - 7.2. EDTA is said to be unstable at ph levels above ~6.2
    If you do figure out the math, update and let me know how it goes.
    #4 slipfinger, Aug 13, 2017
  5. tiger15
    tiger15 Member
    Aug 12, 2017
    224
    78
    4:24 PM
    I didn't buy the iron sulfate specifically for the aquarium to save money. I have the left over for use in my flower bed which I bought it for something like $10 for 5 lb from EBay. I am already dosing Flourish which contains 0.32% chelated iron. But my iron test kit shows non detectable iron level after dosing. So I want to boost iron with what I already have. I am not a chemist and not confident of the math and hope someone can help. I just want to make sure dosing FeSO4 is effective, and most importantly won't harm my fish and plant.
